Old 04-15-2021, 06:45 PM
hgwy407 hgwy407 is offline
Default Contstant CPU Overload Issue
I am finding myself hitting the proverbial wall for the first time in my history of using Pro Tools and want to throw a hail Mary pass here in hope of finding a solution, please.
I am running version 2021.3.0 on a 2017 IMac 27
Big Sur 11.2.3
3.8Ghz Quad-Core Intel Core i5
64 Gb Ram
Radeon 5k video card
I am using an Axe FX III as audio interface via USB.
I have a single analog bass track and a midi drum track triggering EZdrummer and can't get 30 seconds without a CPU error. I am hitting upwards of 127% of CPU memory almost instantly upon hitting the play button. I have the same results opening a new session and importing a single guitar track, which is a mono .wav track.
I have attempted to use all buffer settings from 32-1024. I have also tried moving all plugins to the unused folder and relaunching PT. I have disabled all native plugins with the same end result. Additionally I have tried unchecking dynamic plug-in processing in the playback engine.
All other programs are closed and Activity Monitor confirms that.
I can, and please don't flame me, playback the same tracks and the EZdrummer plugin in Logic Pro and am running between 26 and 39% CPU usage. I realize PT and LP are different animals, but wanted to help shed any additional insight that may bring.
Thank you, any help would be more than appreciated.
Old 04-15-2021, 07:05 PM
Default Re: Contstant CPU Overload Issue
Hi, welcome to the community.
Have you upgraded to Big Sur or made a clean install?
Old 04-15-2021, 07:37 PM
Yes, I have the latest version of Bug Sur and will try and uninstall and clean install and see what happens. Thank you.
Old 04-15-2021, 07:42 PM
Clean install is the only way to success. Also do not use any automatic migration tool but copy your stuff manually
Old 04-15-2021, 07:55 PM
basehead617 basehead617 is offline
That's a rather insane requirement, does it have a basis in support-suggested fact?
Old 04-15-2021, 11:36 PM
Avid only tests clean installs, that is why
Old 04-16-2021, 08:20 AM
I'm with JFreak on this. Migration makes too many assumptions(and Apple cares very little about backward compatibility in hardware or software)
Old 04-16-2021, 08:43 AM
Ben Jenssen's Avatar
My personal experience is Apples Migration Assistant is fine and saves you a lot of ekstra work. It has just never been good with Pro Tools! Solution: don't use the "Transfer applications option" (or whatever it's called), and it will work good. System settings, app prefs, bookmarks, logins, drivers, extensions, installed plugins etc.
So I suggest you do like I did when I went from High Sierra to Catalina and imac to Mini:
Wipe HD, Clean system install, Pro Tools and ilok install - then Migration Assistant without applications migration. Then install other apps.
No problem at all!
Old 04-16-2021, 09:03 AM
I did a complete uninstall and clean re-install and same issue. I imported a single .wav file and upon playback, 120% CPU. I have no other programs that have this issue. I stuck with stock factory plugins that were there with the clean install and no other additions. Perplexing to say the least.
I performed First Aid and a few other diagnostics with other diagnostic programs and there are no hardware issues.
Old 04-16-2021, 09:07 AM
I think perhaps you misunderstand; when we say clean install, we mean boot from recovery partition, format/erase the volume and install the MacOS again from ground up.
CPU overload issue studioman5150 macOS 6 01-13-2016 09:01 AM
Pro Tools LE 7.4cs5 CPU overload issue LindsayJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-29-2008 02:41 PM
CPU Overload. Can't resolve issue. Theecomer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-01-2008 12:09 AM
PT7 Rewire overload issue DrBackshots Pro Tools M-Powered (Mac) 0 11-12-2007 04:33 PM
CPU overload issue ballermann666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-12-2007 05:23 AM
