Disappearing Plug In Preset Lists
Hello
Imported some session data from another studio into my session today, now all my preset lists are missing from my plug ins. How do I sort that out? Kind regards and many thanks. (6.9) |
Re: Disappearing Plug In Preset Lists
I think if you open up a plugin and under the pull down menu where it has "settings preferneces"! there is "set root settings folder" Now i think thats it, but not totally sure Chris
do you have the same problem in a new session?
If so you may want to check the permissions on the Library>Application Support>Digidesign>Plug-in Settings folder. The owner should be set to your username, and the group should be set to admin in the "details" section. Read/Write access should be enabled for both. trashing the Pro Tools preference file (see the troubleshooting thread) can sometimes resolve this as well. regards, |
many thanks for the replies.
indeed trashing the prefs did the trick. simply re-assigning the folder did not work. in the interest of helping others in this case the problem started after importing m powered 7.0 session data, saved as 6.9, into a 6.9 session on another rig. kind regards. |
Unable to get individual IK plug-ins in the PT11 lists | bonzerboy | AAX Plug-ins | 7 | 01-02-2014 03:19 PM |
Plug in Favorite Lists? | visionstudios | Pro Tools 10 | 4 | 02-20-2013 05:36 PM |
Strike not showing up in my plug in lists | alwaysveryloud | Virtual Instruments | 4 | 03-16-2009 04:36 PM |
Disappearing Plug-Ins???? | Be-1ne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-23-2007 01:19 AM |
disappearing plug-ins | RKamrath | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-17-2004 12:48 PM |
