Old 06-28-2021, 10:54 PM
Dion Decibels Dion Decibels is offline
Default Digital Clicks? Apollo x6 & Protools
Hi, Im having an issue with what I believe are digital clicks (tick sounds) happening randomly when recording vocals.
Here's what I'm using...
iMac (Retina 5K, 27-inch, 2017)
Processor 4.2 GHz Quad-Core Intel Core i7
Memory 32 GB 2400 MHz DDR4
Connected to an Apollo x6 via Thunderbolt USB-C cable
Using protools 2021.3.1
Im also using a Rhode NTK mic into a Focusrite ISA-one pre
(Analog not Digital)
Apollo x6 clock is on internal, I've messed with buffer etc. Not sure what I'm missing. Any ideas?? Should I try an SSD Hard Drive? All help is much appreciated. Thank you!
Old 06-29-2021, 12:43 AM
Default Re: Digital Clicks? Apollo x6 & Protools
Originally Posted by Dion Decibels View Post
Connected to an Apollo x6 via Lightning USB-C cable
First of all, did you mean Thunderbolt USB-C cable instead of Lightning USB-C? Lightning connectors are normally just used for Apple iPhones and iPads.
Usually digital clicking is caused by clocking issues. Other than your Apollo x6, what other digital devices do you have connected? Is any ADAT S/MUX optical cables being used? Any S/PDIF connections? Any Word Clock connection? You mentioned that "clocks are on internal." If multiple devices are clocked internal, they are acting as independent "Master Clocks" and not syncing (listening) to each other. Only one device should be "Master" (Internal) and all other devices should be "Slave" (External). This will ensure that all "Slave" devices are syncing to the one "master" device. All devices and software should be set to the same sample rate.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 06-29-2021, 05:38 AM
JingleDjango JingleDjango is offline
No clocking issues for me on my studio workstation:
macOS 10.14.6
Apollo x8
Buffer Size: 128 samples
Internal clock.
Main output pair running SPDIF to my monitor controller. (I had written AES earlier which was incorrect. I don't think there's an AES XLR output.)
Last edited by JingleDjango; 06-29-2021 at 11:27 AM. Reason: I had written AES digital when I meant SPDIF.
Old 06-29-2021, 10:52 AM
paul_g's Avatar
paul_g paul_g is offline
If you have an ADAT attached, you have to go into UAD/settings and change it from Internal to ADAT.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 06-29-2021, 08:47 PM
Yes, sorry! Thunderbolt 3 USB-C
I don't have anything else plugged in to my Apollo. Only my pre amp via 1/4" in.
Only other things being used are plugged in to my computer. A Maschine controller and a hard drive for Time Machine backup.
And, whoops. I meant that my Apollo is in internal...
Thank you
Old 06-30-2021, 01:29 PM
No ADAT. Nothing digitally attached to my Apollo. Only my Focusrite ISA-One pre-amp.
A Maschine Controller & Time Machine HD to my computer.
Old 06-30-2021, 01:35 PM
Yes, sorry! Lightning 3 USB-C
I have nothing digital connected to my Apollo. Only a ISA-One preamp for my mic.
I do have a Maschine Controller & Time Machine HD plugged in via USB to my computer. I'll try with those unplugged next time.
And sorry, my Apollo is on Internal. Don't have anything else using Word Clock or an ADAT, etc.
Thank you
Old 06-30-2021, 07:57 PM
If that is the case, that may be your problem. The Apollo X6 uses Thunderbolt cables, not Lightning. I'm surprised a Lightning cable even fits in the port. It uses a different connector altogether.
Obsidian Dragon
Old 07-01-2021, 11:04 AM
Ughhh, sorry. THUNDERBOLT. not lightning.
Old 07-01-2021, 11:50 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Is the noise only heard in Pro Tools as opposed to Garageband, Logic, Safari, Spotify, etc? If so, might you have a demo plugin in the session? Sometimes those inject noise to persuade the user to purchase.
Are the clicks recorded or just monitored? If recorded, what happens if you record using a different input?
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Im getting clicks and pops through the recording input of my apollo twin mk2 chalz2502 General Discussion 4 05-15-2019 11:23 AM
Best PT11 and Apollo Quad Digital Output to PC gavriil1 Pro Tools 11 3 07-10-2015 09:53 AM
Digital Pops and Clicks Recording Protools S3LX Venue adamfarrell VENUE Live Sound Systems 1 11-05-2014 02:28 PM
Digital Clicks JoeW Pro Tools TDM Systems (Mac) 2 12-01-2007 01:01 PM
Digital Clicks in 6.1 roberts Pro Tools TDM Systems (Mac) 9 11-21-2003 10:01 AM
