And my Elastic Audio went where???
Worked fine in 7.4 went adios in 8. All my EA sessions are back to snail. What happened??
Re: And my Elastic Audio went where???
http://duc.digidesign.com/showthread.php?t=236131
003r/i7-930/LE 8.0.1 cs2 on xp |
Why should I disable it when I NEED it?. Never ran out of CPU power with 7.4 And now I'm getting error -9473 "decrease the H/W Buffer size or increase the DAE playback buffer size." When I do that I get the -9403 error again. I can't even playback my once very playable songs. My number counter is also very herky-jerky. What's up with PT8???? I thought it was supposed to be more CPU friendly and give me the ability to even use more tracks without problems. At this rate I'm going back to PT7.4 |
Try messing with that and some of the other variables on the hardware page.
Have you tried any of the General Troubleshooting steps? Can you give us more information on your system, per the instructions in the Help Us Help You thread, so that we can take a look at possible solutions for you?
I know this is the not usual forum for me (I'm Mac HD).
But I just switched to 8 from 7.4 and this is exactly the case with me. After doing a fresh install of everything on virgin drives. I cannot play back any large band session without 9403 and etc... and crashing my mac. And the only way to make it better was remove elastic audio from my system. And that is no longer an option. Did you ever figure it out?
Brian www.brianjanthony.com MacPro 6 core 3.46 Cheese Grater HDX and HD NATIVE 48 gig Ram PT 2019. Something Sierra 192 IO and 96 IO TDM user way back. PT user since 98. I'm either working, sick, or both. |
General Troubleshooting - Pro Tools LE Windows |
Elastic Audio can't render-then loses audio file | boneboy | macOS | 5 | 04-30-2014 04:57 AM |
Elastic audio taking VERY long to analyze audio? | DJ Hellfire | Pro Tools 11 | 3 | 07-03-2013 05:44 PM |
PT10 elastic audio unable to analyse audio files | chinopepito | macOS | 8 | 03-30-2013 11:03 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
Elastic AUDIO, or Elastic TIME? | SoundWrangler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 11:21 PM |
