Old 01-01-2009, 01:07 AM
saggsy saggsy is offline
Default clip lights not lighting when HPF is engaged ??
Using 003 console's 4 onboard pre's
wondering if anyone else has experienced this problem?
when a track is record armed and there is input coming in - if the HPF is engaged on any of the 4 pre's then the clip ight will not light up on the incoming track, no matter how hard the level is pushed, although the source is obviously distorted.
Matt Saggs
Old 01-01-2009, 09:16 AM
rqstudio rqstudio is offline
Default Re: clip lights not lighting when HPF is engaged ??
Not sure what you mean by HPF, could you be looking at the monitor level and not the input level while listening back?
Old 01-01-2009, 11:37 PM
the High Pass Filter
the ones that come standard on the 4 digi pre's on the 003
Here's the scenario:
-Mic plugged in to channel 1 of 003
-Audio Track in PT set up with channel 1 as input
-Arm Record for that track
-Set gain for channel 1 while speaking through mic
-Track will clip (and clip light WILL show) if gain applied is too high
-If the High Pass Filter switch on this pre or any of the 4 digi pre's is engaged
then even if the gain is pushed too high the meter will light to is full green/yellow section but the clip light WILL NOT light up.
-Take the HPF out of the circuit and the clip light will come on as normal ;(
it happens on any session.
Any help would be appreciated as I know this never used to be a problem (or maybe never really noticed it) - just wonder if any one else has the same issue??
Also - could a moderator please move this thread to the "Protools LE Mac Systems: 003, 002, Mbox, 001" forum - I posted in the wrong one as im actually on a Mac Pro
Mac Pro - OS 10.5.5
003 console
7.4 (what ever the latest update is before 8)
no external drives - actually only running straight to system drive (I know, I know slap my wrist)
Matt Saggs
Old 01-02-2009, 12:10 AM
Sorry I have the 003 rack w/ a PC and don't experience the same problem. Maybe the filter on the console has some kind of gain control, do the levels stay the same before peaking?
Old 01-02-2009, 12:25 AM
wolfskin wolfskin is offline
I can't replicate this behavior on my 002r, but I'm curious...
1. With the record ready PT track assigned to output to a master fader, does the clip light on the master show the same behavior with the clip light?
2. Are you using the peak-hold metering option? Is the behavior the same with both settings?
Windows XP Pro SP3 & Vista Ultimate SP1 / 002R v8.0 w/ MPT2
AMD X2 4800+ Dual Core / 1000 FSB / 4 GB RAM
www.wolfskinrecords.com
www.voodoopilot.com
Old 01-02-2009, 10:40 PM
pennard pennard is offline
Banned
Just tested with my 003 and you are right.
It almost looks like a brickwall limiter.
Doesn't worry me much though.
Old 01-03-2009, 07:38 AM
oh good, so I am not the only one :)
I wonder if Digi might like to chime in on this?
Could it be something that will be fixed by a PTLE update or a firmware upgrade on the 003?
Matt Saggs
Keyboard shortcut to clear red clip lights? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-02-2008 10:36 PM
blue lights or green lights when loading up... zippitydoodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-15-2007 01:58 AM
No Clip lights on Waves 5 roberts Pro Tools TDM Systems (Mac) 3 08-06-2004 01:20 AM
Clip lights on 192 I/O CraigLearmont Pro Tools TDM Systems (Mac) 1 01-18-2004 12:28 AM
Clip lights on C|24 mixmeup ICON & C|24 1 10-16-2001 01:03 AM
