Old 05-04-2022, 09:23 AM
macmuse macmuse is offline
Default MIDI data on track instead of inside a clip
When I click a pencil tool on a MIDI track, it removes the clips and changes the MIDI to inline (MIDI on the track lane without the clips, whatever the term is - a mini piano roll). Is there are way to revert it and get the clips back? And is it only the pencil tool that does this? Thanks.
Old 05-04-2022, 09:44 AM
RobertDorn RobertDorn is offline
Default Re: MIDI data on track instead of inside a clip
Hit - on your keyboard when you have your midi track / instrument track selected to toggle between clip view and notes view in the edit window.
Also, tho change the view and others views (block view, velocity etc) you can click on the dropdown menu below the track name and record/solo/mute knobs, to select the view you want.
Apple MacBook Pro M2 Max, 96GB ram | Pro Tools HDX | Avid MTRX | Pro Tools Ultimate 2023.12 | macOS 13.6.3
Old 05-04-2022, 10:31 AM
Aaahh, so simple. Thank you! There are still some things not used to yet in PT. Was thinking in terms of other DAWs and totally forgot about the drop-downs on the track. What is the key command for this, I looked but didn't recognize what would likely be that.
Old 05-04-2022, 12:30 PM
The minus symbol on your keyboard :) >>> - <<< if you press - when you have your midi/virtual instrument track selected it toggles between notes view and clips view
Key modifier to scroll inside MIDI track kirkbross Pro Tools 2020 2 06-14-2020 10:27 PM
Midi Track Deleting Midi Data In Track Below It appleaudiond Pro Tools 12 1 12-15-2017 09:49 PM
Waveform volume display inside a clip disappears [SOLVED] firmflange Pro Tools 12 2 10-28-2016 10:23 AM
Learning...(clip inside) xy44 General Discussion 6 11-25-2011 08:18 AM
copying Pan Data from midi track to audio track calmborncreator MIDI 2 07-20-2009 11:51 PM
