Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 04-27-2022, 02:14 PM
Dusan Dusan is offline
Default Latest PT, Carbon and M1 question
I have just installed latest PT on Mac Air M1 and connected Carbon using SonnetTech network adapter.
PT is running through Ravenna.
I can only create sessions up to 96 kHz.
Is it Ravenna limitation or Carbon, or the combination?
Old 04-27-2022, 02:19 PM
BScout BScout is offline
Default Re: Latest PT, Carbon and M1 question
Carbon runs a proprietary version of AVB. Where did Ravenna come from?
Old 04-27-2022, 02:25 PM
Started to answer, checked if BScout had already replied. Gave up
Old 04-27-2022, 02:28 PM
jeffro's Avatar
jeffro jeffro is offline
What's the Current Configuration setting in...
AMS > Audio Devices > Pro Tools Carbon > Configure Devices
linkedin
Old 04-27-2022, 02:49 PM
I do apologise guys, Rosetta - the interpretation layer for legacy code, not Revenna.
My bad - I posted it without reading twice.
This is just a test machine - the first M1 Mac.
It is Mac book Air with 16 GB RAM, 8 core 8 GPU.
Old 04-27-2022, 02:50 PM
Was thinking this might get weird with a Merging Anubis or something being involved...
Old 04-27-2022, 02:51 PM
jeffro's Avatar
Thanks for clarifying. So...
linkedin
Old 04-27-2022, 03:06 PM
Regarding configuration of Carbon there is not much you an change.
And when you try to select a sampling rate it only goes up to 96.
Old 04-27-2022, 03:19 PM
The Only choice is Carbon 1-28 24-bit.
I was expecting a way to reduce a number of I/O to get to higher sampling rate but I see no way of doing it.
Old 04-27-2022, 03:22 PM
Are you familiar with getting Carbon to show 192kHz options? Best description I know is here: https://www.pro-tools-expert.com/hom...-carbon-review see "Supports Up To 192KHz" titled section. Gives at least an idea what should be required to see 192 kHz option.
But why would you want to burn those very precious limited DSP resources running at 192kHz (presumably if purchasing a Carbon it was to leverage DSP processing and there is not a huge amount there).
Question regarding both HDX and Carbon nst7 Pro Tools | Carbon 27 05-26-2022 07:26 AM
Question on New Carbon License... tomhartman Pro Tools | Carbon 4 05-06-2021 11:36 AM
Question re Carbon and Using Two DAWS... tomhartman Pro Tools | Carbon 2 05-04-2021 10:03 AM
Carbon DSP Plug-Ins Question Tweakhead Pro Tools | Carbon 17 12-18-2020 11:58 AM
