Old 06-17-2000, 04:55 PM
MT Studios MT Studios is offline
Default Digi 001 and Motu 2408
Has anybody been able to run the Digi001 and The Motu 2408 on the same system. 2408 using Logic or Cubase and the Digi 001 using Protools on a G4?
Old 06-17-2000, 07:41 PM
E. D. Cooper E. D. Cooper is offline
Default Re: Digi 001 and Motu 2408
Yes. No problems (that more memory would not cure.) I've had Logic Platinum running both the Digi001 (through Direct I/O) and the 2408 (via ASIO) simultaneously. But, that set up requires a lot of memory.
In addition, unless you're using a TDM set up, Logic currently does not allow use of the Digi001's extra audio in's and out's for sends and returns to outboard gear like PT LE is capable of. It doesn't let the 2408 do it either.
Old 06-17-2000, 09:42 PM
Will 256megs of due?
Old 06-18-2000, 08:15 PM
I'm assumung you mean 256 meg of ram. ;-)
I'm running on 224 meg. No problems, if you aren't trying to use the 2408 and the Digi001 on Logic at the same time. Even that may not be a problem, with 256 meg and after setting up a streamed lined extensions package with Extensions Manager.
Digi 001/MOTU 2408 Mk2... JediMasterHarker General Discussion 5 01-30-2006 11:03 AM
Digi 001 vs. Motu 2408 jorofino General Discussion 6 03-30-2001 10:08 AM
Digi 001 Vs. MOTU 2408 lfont 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 43 11-14-2000 06:19 AM
Digi 001 vs. Motu 2408 AlinMV 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-18-2000 01:10 AM
MOTU 2408 vs Digi 001 zingsthings 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 11-05-1999 03:12 PM
