Old 08-04-2009, 10:22 AM
Buzzer2000 Buzzer2000 is offline
Default No Sound-Bank change on MidiTrack
Hi! I've a little problem to change Sound-Banks on my KorgM3. I can only select between Combination and Programm mode and get only soundbank A.
The bank-select is greyed out. Any suggestions?
Thanks for help,
Sven.
Old 08-04-2009, 10:39 AM
flommer flommer is offline
Default Re: No Sound-Bank change on MidiTrack
Read the info I posted in this thread:
http://duc.digidesign.com/showthread.php?t=250798
It's all relevant to you as well.
There is also a program called "Cherry Picker" that will let you create your own midnam files. It might be Mac only, IDK
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
bank / program change with VIs typewriter Virtual Instruments 0 11-12-2009 12:08 PM
MIDI Bank Change in 6.1.1 AlecEifel MIDI 0 09-29-2003 09:59 PM
Bank change doesn't work Olle2 MIDI 0 06-16-2003 01:07 PM
Bank change Sammy MIDI 2 12-19-2002 09:53 PM
Bank change w/ PTFree Sammy Digidesign Hardware & Software 0 02-10-2001 05:54 AM
