Pro Tools/ FantomX6 USB problem
Pro Tools doesnt seem to want to communicate with my Roland Fantom via the USB port. It worked great the first day I installed it but after that it just stopped working... I've re-installed the Roland USB driver and everything seems to be working fine with the fantom X and the software editor. The keyboard is communicating well with the computer. Patches load, change etc. So I know it is Pro-Tools that is being stupid.
Any ideas? Things I can download? I think handshaking the keyboard will work, it SHOULD work, but I only have 2 MIDI cables and one is broken. (hence, no handshaking here) There is no reason however why Pro Tools should not work with the USB connection. So here are some configurations: On Pro-Tools MIDI Sudio Setup: Tx channels 1-16 all set to receive, Rx channels all set to send Input Port: Fantom X Output Port: Fantom X Pro Tools does recognize the driver and shows it on the MIDI I/O ports... but it doesnt send or receive jack. On the Fantom: Transmit Program change, bank select, active sensing etc. is all set to "ON" Receive program change, bank select, and Exclusive are all set to "ON" as well... Thanx for your help! |
Re: Pro Tools/ FantomX6 USB problem
(disclaimer -- i probably don't know what the heck i'm talking about.....)
i'm not sure why you want to communicate w/roland via usb for tracking (not even sure you can, but see disclaimer above). i use the fantom's usb capability only when moving data files/samples from my mac to the fantom, otherwise, when used for tracking, it's all midi. there is a setting on the fantom (check around pp. 148-151 in the manual, i'm at work and don't have it with me now) that sets how midi/usb are treated on the fantom. make sure you have the setting you want, and then be sure to save that setting so it starts up that way for you, otherwise, it will default to whatever the last saved version was. good luck! steve |
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'. Empty the trash and restart, then see if everything is working. |
Problem with Pro Tools 9 and Profire 2626. Anybody have a solution to this problem? | Priz | Windows | 1 | 09-25-2011 12:51 PM |
can't install--mac problem or pro tools problem? | tutti_frutti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-10-2011 02:41 PM |
Pro Tools 7.1 as Sequencer to MPC2000xl/FantomX6 | morethanmusicinsc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-05-2011 10:43 AM |
Pro Tools/ FantomX6 USB problem | Deafeye | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-13-2006 08:55 AM |
roland fantomx6 with m-box. how? | carlitos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 12-31-2005 01:46 AM |
