Native Instruments Latency
Helloooo
Yesterday i installed for the first time in my life something like that in my machine It's a NI B4 and there is a latency almost 1 sec from the time a press the keyboard until i hear the sound is it because i m using my PC keyboard ( i havent got a midi keyboard) or is it a common problem that i have to get used to it?? ( i hope not ) Pls help me cause its very anoying Cheers
Vouts! Greece |
Re: Native Instruments Latency
hi
You must use asio drivers for playng soft synths in real time ! If you use Digi001...then man sorry...but there is no asio drivers for it [img]images/icons/frown.gif[/img]
tOMY |
If its the VST version of the NI B4 then your out of luck in PT LE, you will need an ASIO sound card. Looks like there are TDM/RTAS versions of some of the native instruments, but only for MAC. grrrr ...
I have worked around the ASIO problem by setting up my spare latop (IBM 380Z) as a midi module. It runs the VST instruments and things like Reason and then PT LE speaks to it over MIDI (clock/stop/start, etc.) Good luck !
Powermac G4 DP1.25 002R PTle 7.4 Powerbook G4 1.5 Mbox PTle 7.4 |
I picked up a second soundcard, an Audiophile 2496, for about $120 (I think). I use it for asio stuff, and steam the outputs back into the Digi001. Works fine.
Hello Again
Thanks for the replies there is a good and a bad thing I m not using PTools so as you said i have a chance but the bad think is that i dont know anything about ASIO stuff is it something that i could download?? My soundcard is a simple SBLive 1024 [img]images/icons/confused.gif[/img]
Vouts! Greece |
Vouts,
Hi. The first time I installed Reaktor it did the same time. Turned out there was an adjustment in Reaktor to speed it up. I pushed it down to about 100mS and things were fine. On a 500MHz P3 pushing it too much further caused clicks and pops. Look somewhere under the MIDI Setup and see if you can find somethin similar. Take care, Mark |
64 Bit AAX for Native Instruments? | PatriotsBiker | AAX Plug-ins | 48 | 12-25-2013 09:23 AM |
Native Instruments - xfer fee for instruments? | YYR123 | Virtual Instruments | 3 | 10-13-2013 04:47 PM |
omni/native latency vs mbox pro latency | chrisdee | Pro Tools HDX & HD Native Systems (Win) | 34 | 03-30-2012 07:24 AM |
Native Instruments | midnightrambler | Pro Tools TDM Systems (Mac) | 38 | 01-28-2009 09:54 AM |
Tools 6.4 Latency Native Instruments | miniphil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-17-2005 04:49 AM |
