Building a new computer - Recommendations?
Good morning it's me. The crazy one that bought the digi 001 without reading the compatibility web page and now is switching from W2k to Win98.
Ok, once again I have stepped off the edge. Just purchased an 80 gig 7200 rpm Wd Hard drive and found that my Pentium II won't support a drive bigger than 40 gig. Yes I have upgraded the BIOS but no help. Hey the drive was only $167. Sooooo I need help in building a new box. What mother board, CPU, Memory, video card do you recommend. Thanks [img]images/icons/wink.gif[/img] |
Re: Building a new computer - Recommendations?
Abit KG7
AMD 1.4GHZ Athlon (Thunderbird) 266MHz 512 Micrion PC2100 Matrox G400 or450 Video card [img]images/icons/wink.gif[/img]
recordingguy Recording Guy's Studio & Sound www.recordingguy.com Cedar Rapids, IA |
Yep!
You've stepped through the mirror. Swaphappy in Digiland. Your next stop: -There isn't any. The next purchse: -Everything. BTW I believe Recordingguy has the highest track count on the davec test anyone has reported so far. That is a powerful little list up there . Quote:
Here is what I got so far.
CPU: AMD Athlon Thunderbird 1.4 GHZ Motherboard: ABIT KR7A-133 with VIA VT8366 chip set. (Couldn't find the VIA KT133A chip set, do you think the VT8366 will work?) RAM: 256 Meg DDR PC 2100 Video: Aopen TNT II 32 Meg card ATX Turbo Case w/320 Watt Ps EXTRA: Added two more IDE ports with an Ultra 100 IDE expansion card. Total cost so far $520 Drives: Already had 40GIG and 80GIG WD 7200RPM hard drive was $167 Well do you think I have done well or just wasted more bucks? Comments |
Glad i didnt tick off and scare you off. As far as building a new box the people that have built these systems usually do chime in to help if you have any problems setting their config up, and anybody else here usually is happy to chime in to help as well. I think that you will be extremely happy to have a new system over a pII to run ptle. I started off running a pII 333 and even though it worked fine for small projects with few (and i mean few pluggins) the cost of computers now is justification enough to build at least a gighrtz system. Good luck. One last thing, if you have to build one now i understand, but you may want to wait till the xp release comes out to see what digi recommends since you do plan on upgrading to xp (i assume that you may be planning on using your new xp box, but you may decide to keep this box as pt only). Christian |
Abit KT7A - Via KT-133A Chipset 200/266MHZ FSB Sock A Motherboard - RETAIL (Version 1.3) 6PCI, 1 ISA, 1 AGP slot -Retail Box-For AMD Processor. Model#: KT7A *(Need ROUND cables? Click here) Special FedEx Saver Shipping $8.00
- Product Link - Chipset Info -See It! (image count 2 ) -Price Alert (N82E16813123131) (avg rating out of 61 voters) $83.00
Vin NYC Pro Tools 11.3.1 and PT 9.0.5, Macbook Pro 17", OS X Yosemite v10.10.2, 2.2GHz i7 CPU, ATI Radeon 6750M |
Couldn't find the VIA KT133A chip set, do you think the VIA VT8366 will work?
Here are the new results with 512 ram... 24 audio 46 aux 5 stock plugins on each one... I am also running only windown 98SE straight off the disk, with no CRITICAL UPDATES AND SERVICE PACKS from Microsoft...Never connected the machine to the internet either...I'm not sure if that makes a difference or not... Happy Prooltooling!!! [img]images/icons/wink.gif[/img]
Ok, I'm loading Windows 98 SE right now.
Building a computer | cooldude76230 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-16-2007 11:53 PM |
Building a Computer... | misanthropic1002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-27-2005 01:14 PM |
OT: Building a computer | northridgedave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-04-2005 01:39 AM |
Building a new computer for PT 5.0.1 | ddbowen2000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 04-11-2004 01:14 PM |
Building a new computer | Guitarman002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-23-2004 08:12 AM |
