Here is How to setup DM-3200 with ProTools 9 - the old Tascam pdf doesn't work
I am running a DM-3200 into ProTools 9.
The .pdf from the Tascam site didn't work at all, but I got it working 100% and I wanted to share. It is very simple, but I spent a long time figuring it out due to the mix/match of devices you need to do. Had I not had the DM-3200 working with DP I would have never figured it out. Yes - this also enables Transport Control 1- In Audio MIDI Setup create: - Mackie Control (drag to DM-3200 5 Send/Receive ports) - Mackie Control (drag to DM-3200 6 Send/Receive ports) 2- On DM-3200 go to Machine Control List : Add 'HUI Emulate' MAKE SURE TRA BOX IS CHECKED 3- In ProTools go to SETUP/PERIPHRIALS: TYPE: HUI RECEIVE FROM: MACKIE CONTROL SEND TO: MACKIE CONTROL # CHANNELS: 8 TYPE: HUI RECEIVE FROM: MACKIE EXP SEND TO: MACKIE EXP # CHANNELS: 8 |
Re: Here is How to setup DM-3200 with ProTools 9 - the old Tascam pdf doesn't work
Here is how to actually setup to record audio with the DM-3200:
And here is how to configure PT9 to record/monitor on the DM-3200: Setup/Hardware - get the IF/DW mkii showing up here - not PT Aggregate Device Setup/Playback Engine - select IF/DW mkii I'm using a 64 Buffer size (Mac Pro with 9 GB RAM) I/O Under Input/Output add what you need. To test I suggest using one input (which will be Buss 1 on the DM-3200) and a Stereo Output (which for most will be channels 17/18 on the DM-3200). Use your DM-3200 meter bridge (screen on the display or real bridge if you have it) to make sure things are coming/going where they should. |
Eleven rack/Protools/Tascam DM-3200 | guitarbin | Pro Tools 10 | 3 | 11-28-2013 09:24 PM |
ProTools can't detect Tascam 3200 | critictalk | macOS | 4 | 06-02-2013 10:45 AM |
PT9 and TASCAM DM-3200 | critictalk | macOS | 17 | 09-29-2012 11:06 AM |
PT 9 and a Tascam DM-3200 ...help... | jimmyl | Windows | 10 | 11-19-2011 12:43 PM |
Anyone using the Tascam DM 3200? | Johnny2Laps | Pro Tools TDM Systems (Mac) | 0 | 05-05-2006 12:13 PM |
