Old 06-22-2007, 09:21 PM
vjk vjk is offline
Default M-POWERED (new) ONLY 2 INPUTS
Hello,
I've just bought PT M-Powered and am having a few issues with it. I was running MBox 2 prior to this without any problems at all from my PC.
My chipset is a Pentium P45G, which is compatible according to the Digidesign site, and I've had no problems for a year using it with MBox2.
I'm using M-Powered with an M-Audio Delta 1010LT soundcard. The 1010LT works fine with other recording programmes, with all 8 available inputs working.
When I launch PT M-Powered, there are only 2 inputs and SPDIF available, when there should be 8 inputs plus SPDIF.
I've downloaded the latest drivers for the Delta 1010LT and also installed the latest update for M-Powered from the Digidesign site - (7.3.1cs3 I think it is - it's the latest one available on the site anyway.)
M-Powered was able to play back sessions I'd recorded with MBox2 LE, so that seems to be ok - I haven't tried recording in M-Powered yet.
Can anyone tell me how to fix the problem of the inputs, as I obviously bought it so I can record 8 tracks at the same time.
Also, an MBox2 session I loaded into M-Powered played the Audio tracks ok, but I had drum tracks with BFD Lite on an instrument track and they're not playing - BFD Lite is still installed on my PC - do I need to do something to be able to use it in M-Powered?
Thanks in advance...
PT MP 7.3.1cs3,Delta 1010LT,Yamaha MG16/4, AudioTechnica 20/20,Behrenger C2 Mics,Shure SM58,Windows XP Pro,P45G Chipset,P4 3Ghz,2Gb RAM
Old 06-22-2007, 10:41 PM
spkguitar's Avatar
Default Re: M-POWERED (new) ONLY 2 INPUTS
Sounds like you only need to open your I/O Setup window and click the default button on all the tabs.
If you are opening sessions that were started on the MBox, the I/O Settings will be set for the mBox. However, it should prompt you when you open the session that the I/O Settings have changed/are different.
Are you getting those pop ups? Are you ignoring them?
Old 06-23-2007, 07:25 PM
vjk vjk is offline
Thanks SPK....stupid of me to not have thought of it.
I read a lot of your replies to other posts, and it's great to see you sharing your knowledge...thanks.
A while ago I saw a link you posted showing how to colour whole chanel strips in the PT 7.3 Mixer window....I couldn't see it on your Newb link above....where can I find that tute?
Old 06-24-2007, 09:02 AM
spkguitar's Avatar
It's linked from my NewB page;
PT NewB Help -> How To... link -> then under the "Tips & Tricks" heading at the bottom of the page; How to change the track colors
Old 06-25-2007, 05:46 PM
vjk vjk is offline
I followed those instructions but nothing changed. Any other suggestions...?
Old 06-25-2007, 08:51 PM
spkguitar's Avatar
Nope, not really. Those are the instructions to a "T".
Make sure you are holding down all three modifier keys when you click and hold the mouse and drag over the color palette.
Old 06-26-2007, 01:02 AM
vjk vjk is offline
Cool...the colouring worked...I did the same as before but at least now it works.
A very useful tool when visually grouping tracks in the Mixer, which becomes a vortex when it's all grey...fantastic...
How do I utilize the Line inputs when all my XLR inputs are being used? 007audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-23-2009 08:21 PM
Projectmix M-Powered and multiple inputs sladlow Pro Tools M-Powered (Mac) 6 02-24-2009 05:57 PM
Adding Inputs with adat AI3 on M-Powered PT? Dirty Dead Pro Tools M-Powered (Mac) 1 07-26-2008 09:08 PM
Adding Inputs with adat AI3 on M-Powered PT? Dirty Dead Pro Tools TDM Systems (Mac) 3 07-25-2008 06:05 AM
How many inputs and outputs with M-powered?? digidesigner Pro Tools M-Powered (Mac) 0 03-04-2007 03:03 PM
