Octopre dynamic
New here. First post.
Running a scarlett 18i20 3gen with an octopre dynamic along with PT 2021.7 Everything is working as it should except the octopre. I'm getting signal from my mics through my monitors and the meters are bouncing on the front end. But PT isn't recognizing the octopre. Meters are down and when I record it's getting nothing. I feel that I've got everything set up as it should be but am lost as to what is causing this. Hoping it's just something stupid that I'm overlooking. I was using a saffire pro 40 before the 18i20 and wasn't having this issue. |
Re: Octopre dynamic
The Octopre isn't an interface. You need to connect it to an interface so your computer can use the audio it converts. And the only way to do this with the Octopre is ADAT/Lightpipe. You'll need to connect the Octopre to your 18i20 via ADAT and make sure you get a Wordclock cable so the two device are in sync. Otherwise you'll get some terrible sounding sounds.
MacPro 7,1 16-core, 128GB ram, W5700X GPU, RME UFX+, PT 2023.6U. Artist Mix, S1, and PT|Dock. And too many VIs and VEPro machines. |
Octopre dynamic
As above. After you’ve confirmed physical connections are correct, you’ll then need to select those inputs on your channels so make sure everything is correct in the I/O setup. FYI - the lightpipe connection will provide sync. Word clock is optional. Sent from my iPhone using Tapatalk |
Re: Octopre dynamic
I’m using the 18i20 interface with the octopre as a clock source to get 8 more channels.
Everything seems to be working out of both units. And pro tools is recognizing the 3rd gen. Just not the octopre. I tried deleting all the I/O paths and defaulting but I must be missing something. As PT isn’t hearing anything out of the octopre. All the mic inputs are working and I’m getting signal to my monitors. Just not pro tools |
Re: Octopre dynamic
Is your optical source set to ADAT or S/PDIF?
Re: Octopre dynamic
Scarlett set to adat. Octopre is set to internal
Re: Octopre dynamic
The Octopre is merely a mic preamp, not an interface, and can as such not be recognized by Pro Tools in any way.
The Scarlett 18i20 on the other hand is an interface, that can be detected by Pro Tools, and to which you can connect (as you presumably already have?) the Octopre via adat to get additional inputs. If you then (I believe you might have to use the Focusrite Control application for this?) configure the 18i20 to pass the signal on this adat input (from the Octopre) to Pro Tools, and by subsequently configuring the IO Setup in Pro Tools correctly, you should be able to eventually get the signal from the Octopre to a Pro Tools track as an viable input signal that can be recorded. That is the only way the Octopre can be ”recognized” by Pro Tools. Please try this. -matts |
Re: Octopre dynamic
If you're talking about clock source, then you probably have this reversed. Make the Scarlett the Master clock source, i.e. set it to internal clocking. Then, the Octopre, connected via ADAT, will slave to the Scarlett's clocking; set the Octo to external clock. Try that.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Re: Octopre dynamic
Thanks everyone. Looks like I’ll need a bnc cable to run the 18i20 as a master. I’ll try these suggestions and see if I have any luck
Re: Octopre dynamic
Maybe not. The ADAT connection also carries clock signal. Just try it.
FS: Focusrite Octopre MKii Dynamic | crandallwarren | Buy & Sell | 5 | 06-17-2015 06:39 PM |
Focusrite OctoPre MKII dynamic with 192 | theaps | Pro Tools HDX & HD Native Systems (Mac) | 12 | 03-07-2015 12:54 PM |
Factory 003 + Octopre MKII Dynamic Output query | questionoftime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-01-2010 08:41 AM |
003R+ rack with octopre VS Focusrite Octopre x2 through M-audio Lightbridge | Sweepxcore | General Discussion | 12 | 05-24-2009 06:44 PM |
What's SO dynamic about dynamic voice allocation??? | jimlongo | Pro Tools TDM Systems (Mac) | 0 | 03-14-2001 02:52 PM |
