  #21
Old 01-12-2024, 12:12 AM
skylar_battles skylar_battles is offline
Default Re: What I would like to see in ProTools in 2024 !
2023.12 is working well for me. We do have 3 MIDI must-haves though for Pro Tools to "compete" with other software MIDI-wise and should be expected as a minimum for users in 2024.
1. MIDI loop record to playlists
2. Make MIDI recording and punch-ins non-destructive please (MIDI merge and loop recording to separate clips isn't enough for many workflows)
3. Export MIDI clip based on edit selection length
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
  #22
Old 01-12-2024, 12:31 AM
moshuajusic moshuajusic is offline
Is there a way to easily flip automation and/or paste an automation flipped as in panning the opposite way? If not, that'd be useful.
Or just make the other side follow or mirror the automated one without writing the other side, depending on how the sides are linked.
And undo/redo buttons in Avid's plugins. (More flexible than "compare")
  #23
Old 01-12-2024, 05:12 AM
ejsongs ejsongs is offline
Same playlist capabilities for midi/instrument tracks as audio
Fix midi gui verticale scroll slider…been broken for years
Midi strum feature
Access to more ara plugins lie auto tune and revoice
Fix velocity randomize feature…in most forms of music you don’t want a lower velocity on the first note of a phase. I will feel like you are losing energy and people don’t play that way. Downbeats are accented. The velocity random feature is practically useless be cause of this and I have to do things manually.
Ability to draw 808 slides like fl studio
  #24
Old 01-12-2024, 06:11 AM
ja_allen's Avatar
ja_allen ja_allen is offline
I would love for Avid, to just freeze the features for a bit, and work through the code and the bug list, and clean it up a bit. Optimize.
iMAC Pro 27" i9 10 core 32mem 2021/Mac Studio M2 Max 32mem 2023
Focusrite Clarette+ 8Pre/Focusrite Scarlett 18i20/AXE IO
AxeFX III Mark II Turbo/Tonex
ProTools Studio 2023.12.1/OS 14.3.1/14.3.1
https://www.jaallen.org
  #25
Old 01-12-2024, 06:37 AM
Tweakhead Tweakhead is offline
1. Branched Undo/Redo History (an option to enable this mode)
2. Customizable split points for where bus & IO routing spills into another folder (such as in the Mix Window Sends popup. User-configurable in IO Setup with a new split/divider line option for where they occur - Custom-Labelling for headers. eg Mono Sends, Stereo Sends, Atmos Sends, SubMixes, etc.
3. Drum Pattern Editor for MIDI (like Cubase has had since Atari ST days ... 1989)
4. Fast-access Clip Gain amount settings (5 x settings) without needing to stop transport, and go into Pro Tools prefs. (an option for pop-up in the Edit Window header)
5. An option for smoothing-curve-shapes between automation points. (like Cubase has had since 2017)
6. An option for every module in Clip Effects to be completely deactivated on all new or existing audio tracks/clips.
7. 3rd party Plug-Ins allowed in Clip Effects.
8. 3rd party Instruments and Plug-Ins in Sketch.
9. An option to completely remove Sketch from the New Session window and disable completely from Pro Tools (without having to delve into the app package)
10. Complete customization for every single column in Memory Locations (Show/Hide, Position, Width, etc)
11. A User-List within Window Configurations for fast user-switching when collaborating with other Pro Tools users who have a different monitor setup.
12. An option to auto-apply a user-configurable default crossfade between clips when separating.
13. Much faster session load & close times.
14. An option to save screenshots for every single plugin within a session, so that another user can at least get an idea of settings even if they do not own a particular plugin - with a "View Screenshot/Buy Now/24-hour rental" option in the missing plug-in popup.
15. An option for Count-In Metronome/Click to be at the Tempo/Meter of the incoming section, not the previous section. A transparent large video/screen countdown overlay option would be nice too eg 4, 3, 2, 1 •
16. An option to completely hide the tabs at the bottom of the Edit Window (MIDI, Clip Effects, Melodyne, and whatever else is coming down the pipe)
17. More expansive details in CPU Usage. (ie a "shame" list for plugins, VI's)
  #26
Old 01-12-2024, 07:09 AM
Jon_Atkinson Jon_Atkinson is offline
Yes.... 100 times yes...!!!
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
  #27
Old 01-12-2024, 07:43 AM
gives's Avatar
gives gives is offline
One I like and had not thought of, Mastering page (with DDP creation capability)! I could use that for sure for some clients.
Many good points here-:)
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
  #28
Old 01-12-2024, 07:44 AM
gives's Avatar
Cool!
G
  #29
Old 01-12-2024, 07:59 AM
gives's Avatar
While I was looking at this yesterday, a good point here especially for Logic users, but maybe would be some way to incorporate into ProTools if it's not,
WATCH at 13:06 of this YouTube video. About Cubase workflow in film.
https://www.youtube.com/watch?v=B1uyBMXfrCg
G
  #30
Old 01-12-2024, 08:07 AM
wow. very impressive, particularly that auto-sample-mapping from hardware.
Runnind PT 10 and 003 Factory with NEW 2024 Mac PRSWILL macOS 20 01-18-2024 07:08 AM
[FS] $350 [104 Waves Plugins] SSL CLA API Puig Tape DIAMOND Vinyl OMNI Abbey WUP 2024 Electronic1982 Buy & Sell 2 12-05-2023 02:35 PM
[FS] $299 [28 Waves Plugins] SSL CLA API Puig Tape Vinyl OMNI Abbey Kramer WUP 2024 Electronic1982 Buy & Sell 0 11-26-2023 01:58 PM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
