Old 09-13-2013, 10:33 PM
MJarzabek MJarzabek is offline
Default Audio Midi Setup doesn't recognize io on Avid HD Omni Thunderbolt
Hey Everyone,
I have been searching and searching to find a solution to my problem. I have PT 10.3.6 HD and PT 11 HD installed on a brand new macbook pro. For some reason, Audio Midi Setup does not recognize the Omni outputs and inputs. It keeps saying "0 in / 0 out". I am able to use it in PT but the interface is not recognized in other programs.
I have done clean installs on everything pro tools related. My OS is 10.8.3, 16 GB RAM, 2.7 GHz Intel Core i7.
I am running the Thunderbolt Chassis into the Avid HD Omni.
No matter what I do, it doesnt allow me to play itunes, quicktime, etc through the avid core audio manager.
Any advice is appreciated.
Best,
Mike
Still working.
Old 09-13-2013, 11:45 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Audio Midi Setup doesn't recognize io on Avid HD Omni Thunderbolt
Originally Posted by MJarzabek View Post
Hey Everyone,
Best,
Mike
Have you installed the driver?
http://avid.force.com/pkb/articles/e...nload/en379411
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-14-2013, 07:04 AM
nst7 nst7 is offline
With HD, the drivers are automatically installed with the Protools software, so I don't know if that's the issue.
Old 09-17-2013, 01:06 AM
I have done a clean uninstall of the driver and re-downloaded it. It still doesnt work after the install.
When I launch Audio Midi Setup, it says it's a "PCI Avid Core Audio Device" with "0 in / 0 out"
I have also done a clean install of PT 11 and PT 10.3.6. Both versions recognize the omni. However I still can't get it to be my default output in Audio Midi Setup. The "Use this device for sound output" option is greyed out.
Still working.
Old 10-10-2013, 07:33 AM
aaquilato's Avatar
aaquilato aaquilato is offline
I'm having the same problem.
This started after installing ML and PT 10.3.6.
Anyone else?
AQ.
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6
Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9
Black Lion modified OMNI HD w/XB clock
Multiple Black Lion modified 192 FM/XB interfaces
Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native)
Old 10-10-2013, 07:36 AM
aaquilato's Avatar
Originally Posted by crizdee View Post
Chris
So Chris are you saying I (we) need to install this Midi Driver?
I'm running PT10HD4 (PCIx).
It was working fine until I updated to 10.3.6 and then my PCI i/o went from 8/8 to 0/0.
AQ.
PT|HD Thunderbolt + Omni I/O or Mac Pro for quicker performance. davetatemusic General Discussion 9 02-03-2014 08:14 PM
HDN Thunderbolt/OMNI, software without hardware P_J Pro Tools HDX & HD Native Systems (Mac) 1 06-01-2013 01:30 AM
Avid HD Native Thunderbolt and OMNI for Sale drogan88 Buy & Sell 0 03-15-2013 06:47 AM
OMNI-2 HDX = new thunderbolt device with on board HDX prophecy Pro Tools TDM Systems (Mac) 16 10-27-2011 12:35 PM
Audio/midi setup doesn't recognize my mbox 2 academic? jpp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2009 10:49 PM
