Old 05-26-2016, 05:28 AM
shea shea is offline
Default hardware Buffer and Click
using digi 003 rack prolools 11 win 8.1 cant hear the click and cant change buffer size but everything fine in pro tools 10 any ideas guys
Seamus
Old 05-26-2016, 07:58 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: hardware Buffer and Click
Try making your onboard soundcard the default for Windows sounds/audio and leave the 003 for Pro Tools only.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-26-2016, 11:47 AM
Thanks a million Weed that worked perfectly but I still hav no sound from the click . Is there any way for the click to work with 003 pt 11?
Old 05-26-2016, 12:03 PM
This has nothing to do with your 003.
Lots of people have problem driving the click track/plugins properly at different times. You may know how to do this but we can't guess that or exactly what you are doing. What exact click plugin are you using etc? Pro Tools 11 and 12 uses Click II. What exact click plugin are you trying to instantiate on that click track? Screen shots are likely needed here showing all you click plugin and other click settings.
And try opening a different demo session with a click track and seeing if that works. Or creating a new empty session with a click track and post some useful info.
Old 05-26-2016, 12:55 PM
Darryl
I don't have any other click plugins except whats in pt11 I just do what I always did in pt10 go to track tab and create click track or is there another click some where in 11
Thanks again for all the help guys I'm just stuck with out a click
Seamus
Old 05-26-2016, 12:57 PM
Originally Posted by shea View Post
Darryl
Seamus
Again we have no clue what *exactly* you are doing or what the problem here is. What exactly is/is not working? Does playback of standard recorded audio work? Click work then? Click only work when recording? etc.
Post useful details and screen shots or try what I have suggested. Are you doing this from scratch in a new empty session? Or are you importing a Pro Tools 10 session with a click track? We cannot guess... Screen shots... or all relevant click settings.
Old 05-26-2016, 01:25 PM
Darryl
every thing else works perfectly audio midi etc done every thing you said except no sound from click click setting ar normal
Old 05-26-2016, 02:10 PM
Thank you guys Problem solved sorry Darryl. Reinstaled Pt using repair option everything working now
Old 05-26-2016, 03:01 PM
Next time, check Click/Countoff options(under one of the drop-down menus). I bet it was set to only work during record, or maybe during a count-off(probably some random keyboard combination you hit by accident).
Old 05-26-2016, 03:30 PM
Great, but I'm sure what fixed the problem, like Dave I more suspect it was as settings issue.
Unable to locate hardware. Make sure your hardware is connected and turned on. Click ohwhat2 Pro Tools 11 20 01-19-2015 11:47 AM
Hardware buffer size bobmcp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 09-23-2008 06:29 PM
HARDWARE BUFFER - FIX!!!!!!!!!!!!!!!!!!!!!!!!! 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-11-2006 12:42 AM
Hardware buffer size in relation to DAE buffer sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-04-2006 10:30 AM
Hardware Buffer kmanshi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-26-2004 08:10 AM
