Old 08-26-2021, 02:27 PM
freqrider freqrider is offline
Default Re: 003 Rack+, will it work with OSX 10.5 (Catalina)?
This is a more specific way to do it. Worked in Big Sur but I had to do a kextcache update in Catalina to get it working.
https://m.youtube.com/watch?v=F0jq8CXJRBU
Then follow this link for Catalina.
https://www.travelertechie.com/2019/...epair.html?m=0
Old 03-10-2023, 03:28 PM
ksmith24 ksmith24 is offline
Originally Posted by kursattaydas View Post
I can confirm this worked. I downloaded and was able to install most recent OSX digidesign 003 drivers from Avid. I am using 003 in Studio One v5. It comes up as "Avid 003 Rack."
I had to manually label and re-configure the I/Os as they don't automatically come up but all 18 003 outputs are there. No need to sell the 003 and buy another interface :).
Old 03-12-2023, 09:21 AM
Muziekschuur Muziekschuur is offline
I disabled driver protection and installed the driver. My 003+ unit works first time I plugged it in.
Used Catalina on a 2012 MacBook Pro . Run newest version of Protools musician.
BAG END gives THE BEAT!!
Old 04-05-2023, 07:21 AM
drewmaderfromalton drewmaderfromalton is offline
Can anyone verify whether or not Catalina + 003(console) + PT10 will all work together using this method? I'm on Sierra (last "supported" drivers) now and having this annoying glitch where when I go to initiate plugins, the category drop down menus are not visible until I scroll down then the categories show but if I scroll back up the categories go away again. Hoping Catalina might resolve, but don't want to brick my setup in doing so. Thanks!
Old 04-05-2023, 07:56 AM
basslik's Avatar
basslik basslik is offline
You need to post your signature to see what computer you have.
I run a Mac Pro 5,1 with a metal card running OpenCore. This allows me to run any Mac OS via boot screen. I can switch between 12 & 2022.7 with the latest digi003 driver on my Digi 003 console or rack. I guess that disappearing act on the plugins is a known issue for certain unsupported COMBOS. You tried updating to High sierra >?
https://www.youtube.com/watch?v=662ZUo15Cnc
https://www.youtube.com/watch?v=NTBhxYAhAJw
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 04-05-2023, 08:26 AM
I have not tried High Sierra. Sorry, new here and thought I had it showing...in case it doesn't show up now:
Late 2013 13" MacBookPro11,1 Dual-Core i5 'Haswell' 2.4 GHz 10.12.6 Sierra
8GB RAM
003 console
PT 10
Thanks!
8GB RAM
003 console
PT 10
Old 04-05-2023, 10:50 AM
basslik's Avatar
8GB RAM
003 console
PT 10
Thanks!
Can't speak on the Macbook, only my experience on the Mac Pro side.
I know the drivers would work all the way up to big Sur.
Many users here will say that Mt. Lion is the most stable for PT10 I believe. Not sure if you can go backwards on the macbook OS though.
If you could I would just partition two Separate OS. if you need Catalina for other stuff.
"Catalina" & Macs Supported... LightWing macOS 1 06-07-2019 07:49 AM
Catalina Ryan Young Pro Tools 2019 6 06-06-2019 10:20 PM
11 rack - does it still work for you? Sf Audio Eleven Rack 12 01-29-2016 12:36 PM
Does 002 Rack work with MP9??? eoink11 Pro Tools M-Powered (Mac) 9 11-06-2013 03:17 PM
Will 002 Rack work with PT LE 8? WScott615 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-29-2008 03:07 PM
