Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 07-24-2021, 01:20 AM
ilmalvaggio ilmalvaggio is offline
Default Which settings in AVB Audio Entity Configuration?
Hello there!
Which settings should I use in AVB Audio Entity Configuration? Default seems to be 28/56 (44.1Khz-96Khz) but I saw 56x56 in some Avid Video around Youtube.
I also have a problem of audio glitch/chop when playing videos on Youtube/Vimeo in Safari (leatest). No problems on Chrome. (I'm on Catalina 10.15.7 and TB3>TB2 - TB2>Ethernet adapters)
If I switch AVB Entity Settings, sometimes I could temporarily fix it, but the issue comes back after closing a reopening Safari.
It's not a major issue, but just want let you know.
Thanks.
Fulvio
Old 07-24-2021, 03:15 AM
dominicperry dominicperry is offline
Default Re: Which settings in AVB Audio Entity Configuration?
Originally Posted by ilmalvaggio View Post
Hello there!
Thanks.
Fulvio
I'm using the default, but the manual has a complete explanation with tables which show what the differences are. Page 43 (shown as page 51 of the PDF) https://resources.avid.com/SupportFi...rbon_Guide.pdf
If Chrome works and Safari doesn't, use Chrome. You won't find a better answer!
Dominic
Configuration Settings File (PT Loops) EarBud Virtual Instruments 2 05-03-2011 04:51 PM
Configuration settings for hardware insert? HELP! DTrigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-28-2005 10:13 PM
Configuration settings for external plugin? HELP! DTrigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-28-2005 09:56 PM
Rosetta 800 settings/configuration slypstreem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-07-2004 09:18 AM
Logic & Digi 001 working together/PC audio configuration lochgarman1798 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-02-2002 03:02 AM
