Old 04-29-2003, 02:53 PM
spong spong is offline
Default Can I generate MTC or SMPTE without the SYNC i/o?
I am trying to set up my pro tools HD system as the master to drive the autofader system on an AMEK board for mixing. Is this possible without the Sync i/o and if so, how is it done?
Thanks, any input will be much apreciated.
cheers
spong
Old 04-29-2003, 03:29 PM
Tweakhead Tweakhead is offline
Default Re: Can I generate MTC or SMPTE without the SYNC i/o?
Get a friend with a USD or SYNC to create an audio file of the desired tc and put it on an audio track.
Old 04-29-2003, 09:13 PM
Wheelieboy426 Wheelieboy426 is offline
I don't know the first thing about your AMEK, and the audio track thing will work, but ProTools will generate MidiTimeCode and MidiMachineControl. All you need is a basic midi interface (Emagic MT4 or similar)and check the settings in PT. To generate MTC go to the session setup window, check generate tc to port, and put PT online. To generate MMC go to setups, peripherials, machine control. Your AMEK will follow you where ever you go in PT.
Old 04-29-2003, 10:57 PM
doug_hti doug_hti is offline
or you can get a motu MTP AV...a bit shady sometimes, but it generates code and spits it out
it's cheaper, about$500 new
Doug
Sync I/O smpte generate??????? ev33 Pro Tools TDM Systems (Mac) 3 02-11-2009 05:49 PM
Does LE generate and read SMPTE transfers Tips & Tricks 3 10-30-2003 04:18 PM
Need to Generate SMPTE Sussmix Pro Tools TDM Systems (Mac) 1 08-22-2003 12:46 AM
Can Pro Tools le generate SMPTE? pepperman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-20-2002 10:52 AM
SMPTE code generate without USB,SSB,etc KR Pro Tools TDM Systems (Mac) 0 04-25-2001 08:56 PM
