Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
Old 09-28-2016, 06:00 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default Quicksilver G4 has become self aware....
I believe my quicksilver G4 has evolved into intelligent life. It now starts itself up randomly. I don't use it very often, but this morning I came into the studio and noticed it was on, so I shut it down. 30 minutes later, I just heard the startup chime again.
It's running OS 9.2.2... Does anyone remember a problem like this? It is not connected to a network, so I don't know what would trigger it to start up on it's own like this. Zapping the PRAM hasn't helped.
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 09-28-2016, 06:02 AM
Southsidemusic's Avatar
Default Re: Quicksilver G4 has become self aware....
Maybe all the neglected pokιmon have moved in and set themselves up in your ol' Quicksilver Mac
If you feed them after midnight I heard they turn into a Kardashian sister
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 09-28-2016, 07:16 AM
Ben Jenssen's Avatar
I can't really help you with the G4, John, but I can understand your worries.
My Mac Pro has always struggled its self image. It thinks it's a Macbook Pro:
I try not to hurt its feelings by making a big deal out of it, after all it's not hurting anyone.
Old 09-28-2016, 07:47 AM
Make sure wake for LAN is turned off (in energy preferences). Try disconnecting all peripherals and seeing if it still happens. Try swapping the keyboard and mouse (specially to non-Bluetooth ones).
Old 10-06-2016, 07:22 AM
mrhappy1997 mrhappy1997 is offline
Hey John... did you get this sorted? If not, try OS9Lives.com... a growing contingent of OS 9/ DAW users who could help. Most people around here probably don't even REMEMBER OS 9!!
Old 10-06-2016, 07:35 AM
This computer is so old, I don't think it knows what bluetooth is!
I solved it for now by unplugging the power cord. I haven't had time to mess with it but I did try everything Darryl mentioned and all of the other OS9 tricks I remember with no success, which leads me to believe this might be a hardware problem... back around 2003-2004, I had a PCI chassis from the same era that refused to turn off. The issue was solved by replacing the power supply.
- John
Old 10-06-2016, 08:12 AM
Now THAT is my kind of solution!!
Old 10-07-2016, 04:33 AM
Asked a 'OS9Lives' friend about it...
There's an autostart setting in the Energy saver / Schedule prefs / control panel.
Check it.
Old 10-07-2016, 12:06 PM
Triple checked all of the energy saver and wake for network access stuff. All software settings that could make it start up are definitely disabled.
After having it unplugged for a few days, and plugging back in it seems to staying "off".... knock on wood. Possible the NVRAM was the problem, I believe it is reset on this model by disconnecting power for 10-15 minutes. We'll see if it stays off now.
- John
Old 10-08-2016, 12:01 AM
Another friend had the same problem and it was the motherboard so Hopefully yours will be ok now!
HTML code is On
Be aware - Spyware scam! abre Pro Tools 10 1 11-08-2012 12:57 PM
001 --> 002. Things to be aware of... OgnKog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-11-2002 03:18 AM
