Old 12-22-2021, 02:39 PM
zeganaudio zeganaudio is offline
Default Audio is out of sync when importing AAF
Hello
I'm prepping a film that I'm sound editing and mixing and we're running into an issue. I've imported the AAF via import session data and the audio tracks are out of sync. I confirmed that the editor synced everything prior to sharing AAF with me. I attached a screenshot - you can see that the waveforms of the different microphones are not aligned and slip backwards out of sync as you go down each microphone track.
I should mention that upon importing AAF i received this note "Some clips had invalid bounds and were adjusted or deleted. Some renderings were missing." See attachedment for screenshot.
The editor used Davinci to edit.
I'm using Pro tools version 2019.6.0
Mac OS Sierra 10.12.6
thank you so much for ur help
File Type: jpg Screen Shot 2021-12-22 at 4.18.47 PM.jpg (35.2 KB, 0 views)
File Type: png Screen Shot 2021-12-22 at 4.22.42 PM.png (28.7 KB, 0 views)
Importing audio extends the audio clip (I checked sample rate) Lonus Pro Tools 11 1 01-04-2017 05:15 PM
sync issue importing 48 and 44.1 audio glankrudolph Pro Tools 10 2 12-21-2014 09:09 AM
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 09:28 PM
Sync Audio - Editor Used Camera Track Only -Waveform Sync? milosziv Post - Surround - Video 7 11-30-2011 05:26 AM
Importing Waves(tracks) in Sync. Bassart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-17-2001 06:44 AM
