Anyone using M2 MBP for Protools?
The price and spec are pretty good for M2 MBP. Anyone have tried it with Protools? I mainly do post work so the stability of video engine is a must.
Re: Anyone using M2 MBP for Protools?
I have been using a fully loaded M1 mini for over a year now, and while software is still far from native apple silicon, the performance and stability is impressive.
Also my fully loaded M2 air is yet to arrive (should be here soon), but I would not expect a huge performance boost even though it will have 24 gigs of memory compared to 16 gigs of M1. Pro model should in theory be even more impressive as CPU throttling is still a factor with low-end models. I would not expect you having any trouble, just be advised that transition to Apple Silicon is still very much work in progress.
Thanks. Would you mind share your update when your M2 arrives? I don’t have any M1 so I am considering about M2. What version of Protools are you using? And how about it’s video engine performance? Is it only accept Prores 422? Sent from my iPhone using Tapatalk |
Absolutely! Been waiting for it since launch day, but apparently there was huge demand for the fully loaded model.
M2 will be much better for you (compared to M1) because the video engine eats some gigs of memory and that is where M1 is very limited. More info about video engine here.
I know technically M2 will be better than M1. But as you know, it is still not officially qualified by Avid. Also, I know others who can’t enable video engine on M1 MBP, so that is what I worried about M2. Sent from my iPhone using Tapatalk |
You’re not limited on what Codecs will play back as long as they’re supported in Pro Tools. I started with PT 2021.12 on my M1 machine but have kept up with subsequent releases. I suggest you run at least the latest version of PT as this will work best with Monterey. |
My friend got the M1 MBP, but the video engine never activated successfully. Try everything still no luck Sent from my iPhone using Tapatalk |
You don’t state any of particulars regarding your friend such as Pro Tools version, etc. etc. I can assure you it works. As long as you enable the video engine under the playback engine settings. If it didnt work you’d have thousands of screaming MBP users complaint about it.
protools 2019(mac) unable to recognize protools 6 session | carlstuck | Pro Tools 2020 | 7 | 07-26-2020 04:37 PM |
Import session protools 8 mp vers Protools 12 [Résolue] | eryck | Le Forum en Français | 5 | 10-18-2016 11:54 AM |
Protools 12 - Input Audio Window Keeps on opening Protools Cache | soundman1234 | Windows | 0 | 08-25-2016 11:27 AM |
Protools 8 LE/ Error 5000 / Protools freezes constantly HELP! | G ray | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-12-2011 07:09 PM |
setting record levels into ProTools with the intent of mixing in ProTools | Felix | Tips & Tricks | 507 | 02-05-2002 10:17 PM |
