How to call up preset with Ground Control Pro without turning off all effects?
Hi, I recently began setting up my Ground Control Pro to work with Eleven Rack in what I hope will become both my live and studio rig. I've programmed specific presets for different sections in my songs, and I'm using the GCP in the 10 presets/bank setting, so that I can have each bank programmed for a single song, and I can just tap on a single button to move to the next preset when I move from verse to chorus to bridge, etc.
The problem is, when I call up a preset using the GCP, it turns off (bypasses) all of the effects that I have saved under that preset...which makes it pretty useless because I just end up with a clean amp sound. When I'm scrolling between presets on the Eleven Rack unit, it always turns on all of the effects that I had saved, so why is it not working with the GCP? Thanks, Jesse |
Re: How to call up preset with Ground Control Pro without turning off all effects?
Also, to add just one other detail: when I press the patch buttons on the Ground Control Pro, for a split second all of the effects that are supposed to be engaged light up on the Eleven Rack unit, then they instantly all turn off. I've also tried messing with the MIDI thru/CC settings on the ER but nothing I've tried has solved the issue.
You have to - for each and every patch - turn on all the FX you want on the GC, then hold EDIT (upper right) 'til screen changes, click EDIT again, and click YES for SAVE. This is saving the condition to the GC and has next to nothing to do with the 11R.
THoM Facebook |
Ground Control Pro and 11R | wpawley | Eleven Rack | 3 | 11-26-2014 11:18 AM |
Ground Control Pro + ER | solidwalnut | Eleven Rack | 4 | 03-07-2014 02:09 PM |
Eleven Rack & Ground Control Pro MIDI Problem: Amp Output keeps turning off! | sharchik | Eleven Rack | 2 | 10-26-2011 02:06 PM |
11r + Ground Control Pro ? | derker | Eleven Rack | 3 | 11-21-2010 04:15 PM |
Control 24 I/O with unbalanced amp...tie ground or not? | betsy | Pro Tools TDM Systems (Mac) | 7 | 05-06-2003 07:40 AM |
