Old 10-24-2014, 06:57 AM
vickmarine vickmarine is offline
Default No sound unless record enabled
I previously was able to record tracks, and while playing them back be able to play along. Now, the only way I can hear my guitar is to have a track record enabled.
Is there anything that may have gotten changed during recent Windows updates or by running a cleaner such as Glary Utilities?
Win 7 64 bit, PT11, Eleven Rack
Old 10-24-2014, 07:49 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: No sound unless record enabled
It sounds like track input monitoring is set to auto.
Try selecting the track and pressing Alt+K. This should allow you to hear audio even when the track is not record enabled.
Will
System Details
Old 10-24-2014, 11:36 AM
Alt+K has no effect on the problem. Forgot to mention I tried that.
Thanks though!
Win 7 64 bit, i7 chip, 16gb RAM
PT 11 64 bit
Eleven Rack
Old 10-24-2014, 11:51 AM
Here's a weird update:
When I open PT 11 and open a project, I can hear my guitar from the left channel -and if I enable play on the transport, I can play my guitar along with the track and hear it from the left channel only. However, if I enable record on any of the tracks, and then disable record, my live input goes dead -with our without ALT+K enabled. With record enabled, I can hear the guitar, but if I click play on the transport (not recording-play only) again my live input goes dead regardless of ALT+K
PT 11 64 bit
Eleven Rack
Old 10-24-2014, 03:46 PM
Kirby B. Kirby B. is offline
You did save the session, exit PT, turn off the computer and try again, right? Just asking..
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 10-24-2014, 04:01 PM
Drew Mazurek's Avatar
I'm guessing this is an Eleven rack feature because you've never been able to do this in PT.
www.drewmazurek.com
Old 10-24-2014, 06:01 PM
brianiac5150 brianiac5150 is offline
Sounds like you may be experiencing this:
http://duc.avid.com/showthread.php?t=346849&page=2
https://www.youtube.com/watch?v=TbRnyt6PVjc
THoM Facebook
Old 10-24-2014, 06:29 PM
In response to MODERATOR:
I was able to "play" with a track playback in PT11 before I got the Eleven Rack with the M-Audio Fast Track Pro interface. Once I got the Eleven Rack and the uninstall of the Fast Track Pro and the install of the Eleven Rack was complete, I was still able to play along with tracks being played back. Then one day, it was no longer allowing me to do that.
Weird.
PT 11 64 bit
Eleven Rack
Old 10-24-2014, 06:30 PM
Kirby B:
Yep. Did the save, reboot thing many times.
Keep the ideas coming....we'll hit on it one of these days!
PT 11 64 bit
Eleven Rack
Old 10-24-2014, 08:23 PM
Well after posting an earlier, now deleted, confused reply I'll start over.
As Drew pointed out with Pro Tools you should never be able to monitor an interface's input when the corresponding track is not in record mode. This just should not be happening with Pro Tools and any interface.
Now the Eleven Rack does have a local hardware playback mode but Pro Tools does some magic and disables that, other DAWs don't and you'll see users of those DAWs complaining here about that unwanted extra monitoring occurring.
So what went on here before that allowed that some possibilities are...
You were using an aggreagate IO device as the playback erngine and the Eleven Rack was a part of that aggregate. Depending on IO paths setups it is possible you can get output out the Eleven Rack Main Outputs but to not have Pro Tools mute the eleven Rack's internal output. This is not how the product is supposed to be used, and aggregate IO anything is asking for stability problems.
The Eleven Rack was not selected as the Playback Engine at all... in which case it was being used stand-alone and any audio out would have come out from some another source like the computer's built-in output.
You were recording to a different track than the audio you were playing back on... may be easy to do if say accidentally recoding the dry track when you though you were recoding he wet/rig output track.
You were recoding with a non-Pro Tools DAW.
The driver is damaged.
The Eleven Rack is faulty.
Darryl
No Input sound when Record enabled joechucknorris FireWire & USB Audio Interfaces (Mac) 5 11-03-2014 05:10 PM
No sound from track while it's record enabled. Fryder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-12-2010 09:24 AM
No sound with record enabled... mgeiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-13-2008 07:30 PM
Buzzing Sound When Track Record Enabled Rushmore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-16-2007 04:40 PM
No sound when playing back with record enabled mhvoiceuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-01-2007 12:27 PM
