Old 09-10-2002, 05:42 AM
Aquarius Aquarius is offline
Default 1 second bounce....
For a multimedia project, I had to bounce several loops of 1 second or less ;
When it plays on the ProTools, the loop is fine,
but when it's bounced, it doesn't loop at all [img]images/icons/confused.gif[/img]
What do you think about this ?
Is there some kind of latency using "Bounce to disk" ?
Old 09-10-2002, 06:47 AM
Jeff Schmidt Jeff Schmidt is offline
Default Re: 1 second bounce....
If you need something to loop your much better off using "export selected as files"
If you need TDM processing - You could
A.) Caculate the total sample of delay imposed by all your TDM plugs and select an area to compendate for bouncing
B.) BTD and import after bounce. Trim the bounced file so it loops properly and then export that as a file.
Pain in the ass? yes . . . I too have found BTD adds too much delay to keep files looping properly. [img]images/icons/rolleyes.gif[/img]
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate, or whatever 2022.6 is called now
HDX 2 w MTRX, Dadman
9.1.4 Dolby Atmos over Dante to external RMU
Old 09-10-2002, 07:18 AM
DrTone DrTone is offline
Hi Aquarius,
I am also having this problem. Digi needs urgently to do something about BtD. Anyways, there is a workaround: setup an aux and channel all your tracks into that aux. On the aux you can insert your mastering plugs etc and then you feed the output of that aux to a new stereo track (or two grouped mono-tracks for that matter) and set these two in record mode. Loop until you get it right and finally hit record. Afterwards you still need to convert the two .sd2-files but if you have a batch processor, this is rather easy to acomplish.
Good luck,
Dan
Old 09-10-2002, 10:29 AM
davip davip is offline
Just to be clear, it's not BTD that causes this problem, it's plugin sample delay, which is a feature of all digital recording systems.
Dual 2.3 GHz PowerPC G5
2.5GB RAM
OS 10.4.6
HD 2 Accel
PT 7.1cs9
192 I/O
Old 09-10-2002, 02:15 PM
ODC ODC is offline
Hi DrTone,
I'm not shure I've well understood your technique.... [img]images/icons/rolleyes.gif[/img]
After recording the output from the aux channel, how do you export the resulting files ? Do you use "export selected as files" ?
Old 09-11-2002, 12:54 AM
kidfrenzy kidfrenzy is offline
Just to be Clear David. This has been a problem since the start of Pro Tools. All the other DAW manufacturers have fixed the problem and Digi hasn't. BTD sucks! it is a waste of time !
Old 09-11-2002, 06:34 AM
ODC,
either that or you can use the resulting files directly. Be sure to rename them within PT in order to have a .L/.R pair. These can be converted to aiff or dithered or burned to CD etc...
dan
Bounce to Disk issues and bounce to direct show error. SeattleHank Windows 7 01-01-2014 12:41 PM
Elastic Properties Stuck? --pre bounce vs. post bounce alithomas66 Pro Tools 9 2 02-07-2012 05:56 PM
Bounce to disk error - pro tools won't let me bounce the file! HipHopHead Pro Tools M-Powered (Win) 1 05-14-2009 11:13 AM
Bounce To Disk inserts silence at start of bounce - PT 6.4.1 innerbooty Pro Tools TDM Systems (Mac) 1 04-18-2007 08:13 AM
5.1 wont bounce. Says "bounce handler cant keep up try convert after bounce...." Trash Man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-21-2001 08:28 PM
