Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
  #31
Old 08-11-2021, 04:07 AM
dominicperry dominicperry is offline
Default Re: Pro Tools Carbon Laptop Fan Noise
Originally Posted by U.KUSTIK View Post
Hi dominicperry, thanks for the quick response! I've checked if it's a plugin issue, but they seem to integrate flawlessly without using up the CPU. Unfortunately I can't put a MacPro in our budget right now. This would solve my issues I guess. Still my Laptop is in the computability-chart of AVID and my thought was to buy a system that distresses the CPU of my MacBook, not the other way round.
The Carbon itself shows no real fannoise. The thing itself is just a brilliant piece for producers like me. In case it finally will work as planned ^^
I opened a case at AVID-Support and hope they have a quick fix ready. Need it up and running by next week ><
There are certainly people who have had laptop fan problems fixed by Avid. A Mac Pro is inconveniently expensive and unportable.
You may help things using Turbo Boost Switcher. Let us know what happens.
  #32
Old 08-11-2021, 04:26 AM
JFreak's Avatar
JFreak JFreak is online now
Some have reported that using CpuSetter to disable hyperthreading has helped on the fan issue. But you need to do that after every reboot (not wake from sleep).
Janne
  #33
Old 08-11-2021, 07:08 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hello,
Since it's Mac fan noise, this can be resolved by disabling Turbo Boost. On Pro Tools 2021.6 and later go to the Playback Engine and uncheck the "Intel Turbo Boost" setting. Please give that a shot and let us know if it helps.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
  #34
Old 08-12-2021, 05:45 AM
MCorbin's Avatar
MCorbin MCorbin is offline
The added fan speed from the computer is typically caused by the Intel Turbo Boost which is overclocking the CPU. Once AVB is taxing the already overclocked CPU, the fans ramp up even more.
In PT 21.6 there was an option to disable Turbo Boost build into the Playback Engine section.
https://avid.secure.force.com/pkb/ar...e-Optimization
Try disabling Turbo Boost and you should see an improvement in fan behavior.
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
  #35
Old 08-16-2021, 02:00 PM
U.KUSTIK U.KUSTIK is offline
Hi, With the help of the AVID Support Team I was able to solve the problem of the fan noise on a MacBook 15", 2,3GHz, 8core i9, 2019.
Download the latest version of ProTools (at the tine we are at 2021.7)
https://my.avid.com/esd/Product/Download/2538
Then go to Playback Engine and disable "Intel(R) Turbo Boost".
Still the problem with coreaudiod remains. It continues to crush. The AVID Video Engine is eating up over 4 GB RAM when no video is played or even loaded into the project. Seems kind of unnecessary to me.
Kind regrads, U.KUSTIK
File Type: jpg Bildschirmfoto 2021-08-16 um 22.49.19.jpg (12.1 KB, 0 views)
File Type: jpg Bildschirmfoto 2021-08-16 um 22.51.07.jpg (8.2 KB, 0 views)
  #36
Old 08-16-2021, 02:38 PM
JFreak's Avatar
Turbo Boost can be turned off relatively easily. Windows is more tricky, but can be done -- but on Mac there are apps that do it with two clicks, but you need to do it after every boot. To make it permanent you need to be UNIX guru. Which is why I am not posting a script for it, because it would be unethical almost in a sense of sendinf you malware to post a script you have no idea what it does.
Janne
  #37
Old 09-06-2021, 07:47 PM
MattheWood MattheWood is offline
Damn. I wish I saw this thread before I just plunked down the Carbon cash. I too am plagued by the coreaudioid (not responding) and the kernel_task killing my CPUs. I have turned off Turbo Boost in the Playback Engine, but just in idle, I get waves of usage peaking the 8 CPU meters in the System Usage in Pro Tools. Pro Tools slows to a crawl and the fans are cranking, the machine itself is much hotter than when I was previously running a Dante RedNet interface for my setup. I can barely use Pro Tools at this point. Has there been any more progress on this issue? Does Big Sur remedy any of this?
Thank you for your time!
Matthew
Skywalker Sound
MacBook Pro 2020, 2.3 GHz Quad-Core i7, 32 GB Memory, macOS Catalina 10.15.17, Pro Tools 2021.7.0, Carbon Interface
  #38
Old 09-07-2021, 02:27 PM
MCorbin's Avatar
Hey MatheWood, could you start up a support case and let me know the case number? I'm interested to get some more details on your sessions and some logs to get a better picture of what is clogging up your machine.
https://avid.secure.force.com/pkb/ar...-Case-Creation
Thanks!
m
Mark Corbin
  #39
Old 09-07-2021, 05:21 PM
Thank you, yes. My case number is 04240576.
  #40
Old 09-08-2021, 12:52 PM
MCorbin's Avatar
Thanks MatheWood. I'm getting someone to pick up the case today.
m
Mark Corbin
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 03:14 PM
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 06:38 AM
Static Noise with Pro Tools LE and laptop jallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-17-2007 10:43 PM
