Presonus DigiMax FS to 003-proper cable
I am finally getting round to hooking up m Presonus DigiMax FS to my 003 in order to get more inputs. the fine folks (?) at guitar Center sent me home with a TOSLINK cable which would not fit either unit. I took it back (25 minute drive) only to find that the TOSLINK is the only optical cable they carry. They advised me to go to Best Buy and get a regular audio optical cable. It seemed to fit the 003, but would not even begin to fit the DigiMax. Could someone direct me to the proper cable. Would it just be a plain ADAT light pipe cable? Where is the best place to order one from? thanks, GM
Re: Presonus DigiMax FS to 003-proper cable
Toslink is lightpipe is ADAT (well, technically ADAT is a digital audio format carried over optical cables that use toslink connectors)..
What exactly do you mean it won't fit? You pulled out the plugs, right? Sometimes there is a little cover that closes itself, sometimes they are plugged up. The picture on the Presonus website looks like they are plugged...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
YUP! I pulled the plugs from the Digimax. The 003 just has a flexible plastic cover that recedes when you plug the cable in. Hmmmm! I guess I will go back to GC and check out the TOSLINK again. thanks, guys! GM
OK! I think I just figured it out! This should give you guys a grin. i have never jacked with an optical cable before but noticed that the large plastic end on the end of the cable (ok, let`s call it a cable condom) is too large to fit in the opening. Well, I gave it a gentle tug and it slipped off and the cable fits fine.....ok go ahead and laugh..... its ok. I am a tech-tard in the first degree. thanks for the input guys. go easy on me! GM
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Presonus Digimax FS | Mike Andrade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-20-2006 05:50 AM |
Presonus Digimax cable included???? | skyking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-15-2003 01:07 PM |
TO ANYONE WHO WANTS A PRESONUS DIGIMAX LT | PRS4LIFE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-04-2003 11:20 PM |
anyone use the presonus digimax? | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 08-23-2001 03:41 PM |
Anyone Using Presonus Digimax???? | Treble Hum | General Discussion | 0 | 10-12-2000 11:04 AM |
