Old 03-22-2002, 01:17 PM
MarcoM MarcoM is offline
Default Re: RTAS & TDM Together?
Only bear in mind that you can't use RTAS plugs after TDM plugs in the signal chain. You can only use RTAS before any TDM plugs.
Marco Migliari
Producer, Mixer, Engineer, Mastering
www.marcomigliari.com
[email protected]
Old 03-23-2002, 12:23 AM
Samuelsson Samuelsson is offline
Default RTAS & TDM Together?
Is it possible to use RTAS and TDM plugins at the same time in a Mix system? And if it is...How?
Thank's
Old 03-23-2002, 12:30 AM
Shawn Simpson Shawn Simpson is offline
That was one of the new features added in ProTools v5.1. When you go to the inserts, you will have multi-channel tdm, multi-mono tdm, multi-channel RTAS, and multi-mono RTAS to choose from. This is only available v5.1 and later though. Have fun!!
Old 03-23-2002, 12:36 AM
Thank's
Old 03-23-2002, 06:16 AM
Cool!
Thank's so much! [img]images/icons/wink.gif[/img]
Old 03-23-2002, 06:21 AM
Rob Macomber Rob Macomber is offline
You can't use RTAS on Aux inputs or Masterfaders...only audio tracks.
R
Is there a way to convert vst to rtas without vst to rtas adapter? rockguitarist1255 Pro Tools 10 9 01-11-2012 08:35 AM
Why can't I monitor RTAS on Insert A? Line6 Gearbox RTAS Justin1524 Pro Tools TDM Systems (Mac) 3 05-12-2007 07:44 PM
TDM RTAS Vs Native RTAS joybeanstudios Pro Tools TDM Systems (Mac) 7 05-09-2007 09:33 AM
McDSP / HD RTAS vs Native RTAS tclash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-01-2006 08:01 PM
Ozone with wrapper?? or rtas- T-racks RTAS ???? Camilo Toledo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-14-2004 06:35 AM
