Massey L2007 Issues
I am still in PT 7.3.1cs5 but I have had this issue for a while. on 96K/24 bit sessions, If i try to open one of these sessions created a while back, the sound does not come out of the tracks with L2007 (TDM) on them. If I convert to RTAS the track plays fine and if I remove that plug in it plays fine. THis also occurs in new 96K/24 bit sessions if L2007 (TDM) is added to the session.
In a related MAssey issue, the Echo plugin emits lots of hiss and is only multi mono...IS this normal? |
Re: Massey L2007 Issues
Hi-
Not sure about the L2007 limiter, but the echo plugin noise is a feature. That's tape hiss. You need to take the mode off of the vintage setting. Also make sure you have the newest version of both. I know the TD5 had a number of revisions early on. Also the TD5 is only mono. For stereo tracks you need to use multi-mono. For the record I'm on 7.3.1cs4. Don't know if there are any changes in cs5 that would cause them to act differently. Hope this helps, Zac |
The Massey delay plug indeed has that noise built in on some settings. You can control it by increasing your input and dropping the output, or I guess by staying away from those retro settings...
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
I've had the same issue with the L2007 and the Tape Head. When I de-instantiated and then re-instantiated the Tape Head plug, the problem went away.
No such luck with the L2007. He's probably aware of this issue. He's also very nice and quick to respond to emails. I'd just email him. |
Massey L2007 vs. PSP Xenon? | ctyelvis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-17-2010 11:59 AM |
Massey L2007 vs. PSP Xenon? | ctyelvis | Pro Tools TDM Systems (Mac) | 3 | 04-16-2010 09:10 AM |
Massey L2007 settings | Waveform | Post - Surround - Video | 1 | 06-08-2007 05:37 AM |
My NEW TL Space and Massey L2007 plug with a clip | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-26-2007 11:43 AM |
Massey L2007 Mastering Limiter | Matt82au | Pro Tools TDM Systems (Mac) | 69 | 12-06-2006 08:08 AM |
