Multiple regions volume
Hello,
I'm trying to modify the volume of multiple regions at a time, but it doesn't seems possible. Even when selecting multiple regions it will change the volume one by one. I tried to press any key (cmd, alt and so on) and clicking on the fader icon of the region and it will still do one by one. Anyone has any advice, please? Thanks. |
Re: Multiple regions volume
Switch your track to volume view, select all of the regions whose volume you want to adjust, then use the trim tool to adjust the volume line across the selection in a single operation.
Jonathan S. Abrams, CEA, CEV, CBNT Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10) |
So is not possible then.
I want to change the region volume and then the track volume if needed. Changing one by one is very time wasting. :-( |
Volume automation-wise - if you need to adjust non-contiguous regions - there is no nice way to do it, instead of grouping the tracks you want to adjust. Unfortunately if there are regions inside the selection, that are not supposed to get adjusted, they will get adjusted as well. In this case you will have to move the non-adjustable-regions to another track, then select all the desired regions and change the automation. Hope this helps, Timothy |
Thanks a lot for your answer.
I would be very happy just to have to option to change the region volume to consecutive regions but it definitely doesn't work here. I made sure I was with the Object Grabber and selected few regions. Kept selected and tried to lift the volume of one of those (tried with all of them). Doesn't work. Tried also helping with Shif key, ctrl key and so on but definitely doesn't work here. Has my PT a bug ? |
Use the smart tool. select the regions. Right click over the clip gain icon. Select "Show clip gain line". Now hover the mouse near the line. It turns into an interesting looking tool. It's a volume grabber with a mini clip gain fader. This works great and you don't need modifier keys. It also won't deselect when you change other clips. Awesome!!
Another point to be made here. Clip gain is not the same as volume. Clip gain changes the source gain only! A volume fader from the mixer changes the output of the source and the fx that follow it. For example, If you have a compressor on the track and it's on pretty hard, you won't hear much volume change when you change the gain but you will hear more compression as the compressor squashes the high gain back down. You will hear a difference in loudness if you change the channel volume fader in the mixer. You were using the term volume and that concerned me a little.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
This is possible... I have to find the thread, but you can select multiple regions (separately in the same track and multiple tracks) and then adjust volumes and or fades.... I might not have time to find it but search the DUC.... There is even a video that shows how to do it.
I finally figured this out (for Mac at least).
View menu>Clip>Clip Gain Line Then, use the grabber tool, but NOT on the clip gain line. Select your regions (again..not near the clip gain line...you want the regular hand symbol). Then you must hold SHIFT AND CONTROL (not Command) use your UP AND DOWN arrows and it will move all clip gains selected in increments of .5. You can't use your mouse or trackpad, as this won't work. Only the up and down arrows, as far as I can tell! |
Fades on multiple regions. | cosboud | macOS | 2 | 03-07-2012 09:49 PM |
Wav to mp3 ... multiple regions. How? | tpthai2 | macOS | 4 | 12-19-2011 10:57 AM |
Extending Multiple Regions | zwiersd | Tips & Tricks | 4 | 04-04-2009 10:23 PM |
trimming multiple regions | hagai2003 | Tips & Tricks | 5 | 08-15-2008 08:18 PM |
how to select multiple regions... | chris.d | Tips & Tricks | 2 | 01-23-2003 09:48 AM |
