Old 08-27-2008, 07:59 AM
Hollow Body Hollow Body is offline
Default PTools Not Showing new files in track window after burning in plug-in
Hi. I started having this problem about 3 weeks ago. Running PT 7.3, Digi 002 rack, Windows XP, Pentium 2.53Ghz
When I highlight an audio track in the track window and burn a plug-in into it (could be any plug-in, like an EQ, or Compression, or gain up or down etc..), it goes through the motions but then leaves the old file up on the track. It DOES create the new "altered" file in the audio folder, but I have to import it into the project and then delete the track where the pre-altered file is. (or just paste over it.) This is kind of a pain.
In the past, as we know, it just over-wrote the new "altered" file over the old one.
Anyone have any ideas?
Thanks!
-Doug
Old 08-27-2008, 08:25 AM
sw rec sw rec is offline
Default Re: PTools Not Showing new files in track window after burning in plug-in
Do you have "use in playlist" highlighted on the plugin?
Old 08-27-2008, 08:42 AM
Default Thanks! - Re: PTools Not Showing new files in track window after burning in plug-in
Hi SW Rec,
That was the ticket! Thanks a lot. I guess for 5 years that "button" has been automatically highlighted / on and for some reason it wasn't now. I had never even looked at it before.
Thanks again! I really appreciate it.
Wave files in Audio track not showing -Please help??? rcd Pro Tools TDM Systems (Win) 5 01-03-2011 08:50 AM
Plug-ins not showing in plug-in window ndaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-27-2007 10:42 AM
AudioSuite Plug-ins not showing on track plug-ins dappmasters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-23-2006 06:35 AM
Can I have different sends showing for each track in the edit window? sevan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-08-2001 05:44 AM
Burning on CD-RW from PTools/digi001 problem Tom Harmon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-27-2001 02:49 PM
