No MIDI Devices (003Rack + 8.0.3 or cs2)
I don't see any devices listed in the "MIDI Input Enable".
I've tried reinstalling the drivers via DigiDrivers.exe. I've ensured that MMERefresh is running at startup. I've tried refreshing the preferences folder. I've also tried updated Pro Tools. First I tried 8.0.3 (but that didn't fix the issue) so I continued to 8.0.3cs2 (and that didn't fix anything either). I don't want to re-install if it can be avoided. Please let me know if you've had this problem and I'll be happy to hear any possible solutions. Sandra Report follows: HTML Code:
SiSoftware Sandra Computer Model : Dell Inc XPS 630i Domain : Withheld Host Name : Withheld User : Withheld Processor Model : Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Speed : 2.83GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing Computer Mainboard : Dell Inc 0C113J BIOS : Dell 1.0.13 05/05/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3GB DIMM DDR2 Chipset Model : Dell C55 Host Bridge Front Side Bus Speed : 4x 333MHz (1.33GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 400MHz (800MHz) Memory Module(s) Memory Module : Kingston KCM633-ELC 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Kingston KCM633-ELC 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Kingston KCM633-ELC 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Memory Module : Kingston KCM633-ELC 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3) Video System Video Adapter : NVIDIA GeForce 9800 GT (2x 112 SM4.0 1.4GHz, 2x 512MB DDR3 2x900MHz, PCIe 1.00 x16) Video Adapter : NVIDIA GeForce 9800 GT (2x 112 SM4.0 1.4GHz, 2x 512MB DDR3 2x900MHz, PCIe 1.00 x16) Graphics Processor OpenCL Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 497.6MB 2x900MHz) OpenCL Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 497.7MB 2x900MHz) Compute Shader Processor : NVIDIA GeForce 9800 GT (112SP 1.4GHz, 497.6MB 2x900MHz) Compute Shader Processor : NVIDIA GeForce 9800 GT (112SP 1.4GHz, 497.7MB 2x900MHz) Storage Devices WDC WD3000HLFS-75G6U1 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) : 279GB (C:) (E:) Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) : 932GB (D:) DELL USB HS-CF Card (USB) : N/A (H:) DELL USB HS-xD/SM (USB) : N/A (I:) DELL USB HS-MS Card (USB) : N/A (J:) DELL USB HS-SD Card (USB) : N/A (M:) Generic Flash HS-CF (USB) : N/A (N:) Generic Flash HS-COMBO (USB) : N/A (O:) Optiarc DVD+/-RW AD-7230S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) Logical Storage Devices Recovery (E:) : 15GB (NTFS) @ WDC WD3000HLFS-75G6U1 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) OS (C:) : 264GB (NTFS) @ WDC WD3000HLFS-75G6U1 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) Audio Data (D:) : 932GB (NTFS) @ Seagate ST31000528AS (1TB, SATA300, 3.5", 7200rpm, NCQ) Optical Drive (F:) : N/A @ Optiarc DVD+/-RW AD-7230S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Removable Drive (H:) : N/A @ DELL USB HS-CF Card (USB) Removable Drive (I:) : N/A @ DELL USB HS-xD/SM (USB) Removable Drive (J:) : N/A @ DELL USB HS-MS Card (USB) Removable Drive (M:) : N/A @ DELL USB HS-SD Card (USB) Removable Drive (N:) : N/A @ Generic Flash HS-CF (USB) Removable Drive (O:) : N/A @ Generic Flash HS-COMBO (USB) Peripherals LPC Hub Controller 1 : Dell MCP51 LPC Bridge LPC Legacy Controller 1 : ITE IT8718F Audio Device : Dell MCP51 High Definition Audio Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : Dell MCP51 Parallel ATA Controller Disk Controller : Dell MCP51 Serial ATA Controller Disk Controller : Dell MCP51 Serial ATA Controller USB Controller 1 : Dell MCP51 USB Controller USB Controller 2 : Dell MCP51 USB Controller FireWire/1394 Controller 1 : Dell FW322/323 IEEE1394 OHCI FireWire Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Peripherals Media Player : () Media Player : () Media Player : () Media Player : () Media Player : () Media Player : () Network Services Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows Vista Business 6.00.6002 (Service Pack 2) Platform Compliance : x86 Windows Experience Index Current System : 5.0 Performance Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Last edited by David Sabine; 10-29-2010 at 02:55 PM. Reason: Added more info. |
Re: No MIDI Devices (003Rack + 8.0.3 or cs2)
I'm not sure how the DigiDrivers.exe reinstalls the drivers, but you could try to repair the installation through Programs and Features in the Control Panel - or whatever it's called in Vista. If still a no-go, I'd do a full uninstall and reinstall - it'll probably be faster in the long run than a lot of troubleshooting that might not even fix it.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I have the same problem with my 002Rack and haven't been able to use midi since PT6.9. I had a post awhile back and posted my Sandra report and never received any additional suggestions. I thought maybe it was my firewire card so I purchased one of the suggested models (Siig) but still can't get midi ports to showup in Protools. I installed Protools on my wife's Macbook Pro (intel core duo 2.4 ghz) and my midi ports for the Digi002 were there without any issues. I have MMERefresh running and have gone through all the troubleshooting that I can but haven't been able to solve anything.
Have you gone to Setup>midi>midi studio and added/create devices there? I have had no major midi issues going all the way back to 6.4
I've tried this with the MIDI port on the 003 and also with USB MIDI devices. Nothing seems to have worked so far. The most troubling issue is that MIDI used to work GREAT on this exact system. The only things that have changed in the system (since MIDI was working) are Pro Tools updates and Windows updates. |
I don't know what else to try. My midi is all working fine here
I had similar problem when I upgraded to version 8 - and was actually why I joined the duc to post for help. I tried everything
My solution was doing a 'repair' while running setup with Windows in stripped down minimum config (drivers, services, startup, UAC). I think this was on v8.01. Running setup/repair not in minimum mode was not allowing something to happen to register the MIDI components in windows I believe... Since then I've done many upgrades/downgrades/uninstalls/reinstalls and MIDI continues to work. I use Acronis now to avoid experiences like my old MIDI problem. Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized. Google the DUC Search Avid |
I am having a similar problem. There are no devices listed in the MIDI Input Enable.
I have verified that MMERefresh.exe is running. Under Device Manager the Digidesign 003 Rack appears under Sound, video and game controllers but there is no listing for any MIDI device. I have set up the minimum Windows configuration, and tried re-installing PT 8 with the "repair" option with no change. My keyboard will cause the MIDI In light to flash on the front panel so I know MIDI data is passing into the interface. 3-5-2011: Here is an update--- after much research and testing cycles I have determined that it can be solved! Thanks to all who have contributed to this issue, each bit helped me some. To fix the problem uninstall Pro Tools 8. I know it is a pain, but this seems to work reliably. Then configure Windows XP to "minimal settings" as shown below. then re-install PT. Digi 003 Midi port shows up then in the MIDI Input Enable. Last edited by thecount4; 03-05-2011 at 09:33 PM. Reason: Found a workaround |
This workaround applies to PT 8.0.3 Win XP SP3.
The web still works and the Midi device shows in the list as: Digidesign 003 port 1 Something in the following list makes the Digidesign 003 port 1 not show up in the Midi Device Enable list if it is turned on. I'm not sure the exact item that causes the conflict problem. In order to be certain, if you have the time, you could turn each one that is not started back on individually and check to see if the interface still shows up in the Midi Device Enable. The following shows what you can disable and still run the computer. Here are the details of the services setup: HTML Code:
Name Status Startup Type Log On As Automatic Updates Started Automatic Local System AVG Firewall Started Automatic Local System AVG WatchDog Started Automatic Local System AVGIDSAgent Started Automatic Local System Background Intelligent Transfer Service Started Automatic Local System COM+ Event System Started Manual Local System Computer Browser Started Automatic Local System Cryptographic Services Started Manual Local System DCOM Server Process Launcher Started Automatic Local System DHCP Client Started Automatic Local System Digidesign MME Refresh Service Started Automatic Local System digiSPTIService Started Automatic Local System DNS Client Started Automatic Network Service Event Log Started Automatic Local System Extensible Authentication Protocol Service Started Manual Local System Fast User Switching Compatibility Started Manual Local System HTTP SSL Started Automatic Local System Logical Disk Manager Started Manual Local System Logical Disk Manager Administrative Service Started Automatic Local System Network Connections Started Manual Local System Network DDE Started Automatic Local System Network DDE DSDM Started Manual Local System Network Location Awareness (NLA) Started Automatic Local System Plug and Play Started Manual Local System Remote Access Connection Manager Started Manual Local System Remote Procedure Call (RPC) Started Automatic Network Service Remote Procedure Call (RPC) Locator Started Automatic Network Service Security Accounts Manager Started Automatic Local System Security Center Started Automatic Local System Server Started Automatic Local System Shell Hardware Detection Started Automatic Local System Simple TCP/IP Services Started Automatic Local System SSDP Discovery Service Started Manual Local Service System Event Notification Started Automatic Local System TCP/IP NetBIOS Helper Started Automatic Local Service Telephony Started Manual Local System Terminal Services Started Manual Local System Universal Plug and Play Device Host Started Automatic Local Service WebClient Started Automatic Local Service Windows Image Acquisition (WIA) Started Automatic Local System Windows Management Instrumentation Started Automatic Local System Windows Management Instrumentation Driver ExtensStarted Automatic Local System Wired AutoConfig Started Automatic Local System WMI Performance Adapter Started Automatic Local System Workstation Started Automatic Local System Automatic Local System .NET Runtime Optimization Service v2.0.50727_X86 Manual Local System Alerter Disabled Local Service Apple Mobile Device Manual Local System Application Layer Gateway Service Manual Local Service Application Management Manual Local System ASP.NET State Service Manual Network Service Audio Service Manual Local System ClipBook Disabled Local System COM+ System Application Manual Local System Distributed Link Tracking Client Manual Local System Distributed Transaction Coordinator Manual Network Service DM1Service Disabled Local System Error Reporting Service Manual Local System Fax Manual Local System FLEXnet Licensing Service Manual Local System Health Key and Certificate Management Service Manual Local System Help and Support Manual Local System HID Input Service Manual Local System IMAPI CD-Burning COM Service Manual Local System Indexing Service Manual Local System InstallDriver Table Manager Manual Local System iPod Service Disabled Local System IPSEC Services Manual Local System Java Quick Starter Manual Local System Messenger Manual Local System Microsoft Office Diagnostics Service Manual Local System MS Software Shadow Copy Provider Manual Local System Net Logon Automatic Local System Net.Tcp Port Sharing Service Manual Local Service NetMeeting Remote Desktop Sharing Manual Local System Network Access Protection Agent Manual Local System Network Provisioning Service Manual Local System NT LM Security Support Provider Manual Local System NVIDIA Display Driver Service Manual Local System Office Source Engine Manual Local System Performance Logs and Alerts Automatic Local System Portable Media Serial Number Service Manual Local System Print Spooler Manual Local System Protected Storage Manual Local System QoS RSVP Automatic Local System Remote Access Auto Connection Manager Manual Local System Remote Desktop Help Session Manager Manual Local System Remote Registry Manual Local Service Removable Storage Manual Local System RIP Listener Manual Local System Routing and Remote Access Automatic Local System Secondary Logon Manual Local System SiSoftware Deployment Agent Service Manual Local System Smart Card Manual Local Service System Restore Service Disabled Local System Task Scheduler Manual Local System Telnet Manual Local System Themes Manual Local System Uninterruptible Power Supply Manual Local System Utility Manager Manual Local System Volume Shadow Copy Manual Local System Windows Audio Manual Local System Windows CardSpace Manual Local System Windows Driver Foundation - User-mode Driver Framework Automatic Local System Windows Firewall/Internet Connection Sharing (ICS) Manual Local System Windows Installer Manual Local System Windows Media Player Network Sharing Service Manual Network Service Windows Presentation Foundation Font Cache 3.0.0.0 Manual Local Service Windows Time Wireless Zero Configuration Disabled Local System HTML Code:
sttray mobsync avgtray MMERefresh ctfmon |
003rack+win7-64bit PC+digi asio driver = midi input (5pin) problem! | Slaido | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-22-2011 06:32 AM |
How to restore Midi Devices & Midi Patch Names | JLEpperson | Pro Tools TDM Systems (Mac) | 1 | 12-31-2009 12:31 PM |
midi problem with digi 003rack | Sonnao | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-28-2009 08:58 AM |
MIDI settings? 003Rack+ and Motif XS8 - Thx | 1959 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-30-2009 12:55 PM |
Midi Devices not showing up after setting up Audio Midi Setu | nick535nak | Pro Tools TDM Systems (Mac) | 4 | 09-23-2007 01:15 AM |
