Old 10-07-2023, 02:59 PM
largoman largoman is offline
Default Inserts not showing buses.
I`M trying to insert reverb to a track. When I click on Sends - Bus , I only get one choice. This "Bus" is not in my I/O list. (picture below). The normal Buses
do not appear. Can anyone explain how to delete this "Bus" so my Busses show on my Inserts list. Thank you for your help.
Sorry for the small pics , my PC does not "print page". I am trying to Snip them.
Intel(R) Core(TM) i5-8400T CPU @ 1.70GHz 1.70 GHz
12.0 GB (11.8 GB usable)
64 Bit operating system
Windows 11
Old 10-07-2023, 03:21 PM
Default Re: Inserts not showing buses.
Looks like are showing us the (edit:) Setup>IO>Input page not the Setup>IO>Bus page and that custom colors you have are fairly illegible especially after DUC image downsampling. Please post images to a photo or file sharing site and just put the link here.
Old 10-07-2023, 03:26 PM
BScout BScout is offline
I can’t tell which (due to your terrible colour scheme) but in I/O setup you are looking at either inputs or outputs.
Neither of those are busses.
Go to the bus tab.
Create your busses there.
Then in the column to the right on that tab, map the bus to a physical output (drop down.)
In that drop down you’ll see your physical outputs.
Then those newly created busses will be available and will send audio to a physical output.
Old 10-07-2023, 04:20 PM
its2loud its2loud is offline
Alternatively, choose New Track from the Send drop-down list. Name it whatever you want. This will automatically create the bus and route it to the new track. If you don’t need the track, just delete it.
Old 10-07-2023, 07:34 PM
Thank you. This will be very helpul in the future.
Old 10-08-2023, 12:23 PM
You're right. I dropped down the input window. Thanks for pointing that out. Went to Bus window , defaulted the bus I/O and everything was fine. Thank you. Will also post links to photos from a file sharing site next time.
Old 10-08-2023, 01:41 PM
BScout , Yes. I dropped down the input window. As you said , I went to the Bus tab , but just deleted the buses that were there and renewed to the Default Buses. Thanks for explaining how to route a new Bus for a specific new track. Will use in the future.
Sidechaining: only mono buses showing gdgross Pro Tools 2018 16 12-14-2018 02:26 AM
MPX-L not showing in Inserts... cjl Pro Tools 12 4 06-13-2016 06:21 AM
Inserts not showing up RoxyRiot macOS 1 09-13-2013 06:58 AM
Instruments not showing in Inserts robert1 macOS 0 02-15-2013 08:11 PM
order of buses/inserts booglebop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-05-2004 12:12 AM
