Audio Track Limit - What happens when exceeded?
Does ProTools 12 display the number of active Audio tracks anywhere?
I am possibly exceeding the limit, as some audio tracks simply won't sound, as well as some AUX tracks which I thought were limitless (I am separating channels in a virtual drum instrument.) and these too are silent, despite their meters working. Regarding the silent audio tracks -- they look normal, meters working, etc, but I can not get sound out of them - either via a Buss or directly to the Analog Output 1-2. Is it expected behaviour that tracks simply won't sound without warning if limits are exceeded, or should I look for another cause? I hav no idea what that might be. Thanks Geoff |
Re: Audio Track Limit - What happens when exceeded?
You're dealing with another problem - probably I/O or Playback Engine related. You can always see how many active voices you're using in the System Usage Window. When you exceed the max track count, PT will throw a warning that you've exceeded your maximum and make some tracks inactive.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Thanks Rich, you are correct. I found I had some time ago created a VCA channel which some tracks/channels were assigned to, and it was muted. I didn't initially make the connection.
Thanks for the reply, much appreciated. Geoff |
Obama Should Have an Audio Czar - 24 Track Limit | Barry Johns | Pro Tools TDM Systems (Mac) | 35 | 06-29-2011 09:02 PM |
USB Bandwidth Limit Exceeded and Audio Problems | Zoltta | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 04-04-2009 03:51 PM |
CPU Usage limit exceeded! Help Me! | bluesguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 09-18-2005 10:01 AM |
Does the 32 audio track limit include Aux tracks? | viewstart | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-20-2005 03:08 AM |
What happens when max track-count is exceeded? | Allan Speers | Pro Tools TDM Systems (Mac) | 10 | 08-13-2002 12:27 AM |
