Old 03-19-2014, 06:38 AM
The Weed's Avatar
The Weed The Weed is offline
Default Avid TC/E Plug-In...
Is anyone else seeing this:
I do a lot of 10, 15 and 30 second commercials, most of which are overwritten and require time compression. Prior to PT 11, to time compress a file, I would type in the length I wanted the file to be, hit enter and then render.
In the new TC/E plug-in in PT 11, when I type in the length I want and hit enter, the time jumps to much larger than the original time. I have to go into the original length shown and, between the colons (:) type in the time. For example, if the original time is 0:31:105 and I want the file to 29.5 seconds, I have to change the 31 to 29, then change the 105 to 000, then render.
Not a show stopper, but time consuming. Bug?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 03-19-2014, 07:20 AM
Default Re: Avid TC/E Plug-In...
I do time stretching in Wavelab, but could this not work; select to show time>consolidate(if needed) and use the TC/E tool to drag the end of the audio back to the time you want?
Old 03-19-2014, 11:28 AM
mesaone mesaone is offline
Does it do what you want if you just type a colon first?
example: you have a 30 second clip you want to be 28 seconds. Audio suite TC/E, select the length field, type ":28" and hit enter.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 03-19-2014, 08:21 PM
The Weed's Avatar
Not that I remember. IIRC I have to individually type the numbers inbetween the colons.
albee, I could use the TC/E Trim Tool, but sometimes it's a time that needs to be precise.
I just wanted to know if others were seeing the same issue. Then it's time to report a bug.
Thanks,
SonoBus
Old 03-20-2014, 09:27 PM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
I need to this periodically as well. However, I don't work using the audiosuite plug in. Instead, I create a clip group of the files, or playlist and consolidate the edits, set my grid to seconds/milliseconds and TCE to the grid value.
Sign up for all things....AWESOME!
Kris
May the music move you
Old 04-01-2014, 03:47 PM
The Weed's Avatar
Update. I've found typing in as follows, as an example, will do what I want:
Original: 30.125 seconds
I type in 0:29.500 and hit enter and the time stays. Must put in 0: at beginning.
Cheers,
SonoBus
Old 04-01-2014, 04:31 PM
That's what I thought was the fix, only I thought you just needed to type the colon and not the zero. As in :29.5 instead of 0:29.500. That's how mine reacts here, at any rate.
Old 04-01-2014, 06:24 PM
The Weed's Avatar
Tried that, no joy. Have to have the 0:
Maybe a PC/Mac difference?
SonoBus
Old 04-01-2014, 06:51 PM
btate btate is offline
Grid mode and TCE trim tool will be precise as you want.
New Avid TC/E Plug-In issue... The Weed Pro Tools 11 2 12-24-2013 10:29 AM
Do the AVID Pro plug ins ever go on sale? propower Pro Tools HDX & HD Native Systems (Mac) 13 12-21-2013 11:23 AM
PT 10 WITHOUT avid PLUG-INS? javisoa19 macOS 2 03-12-2013 06:33 AM
free avid plug studiojimi Pro Tools TDM Systems (Mac) 3 05-11-2012 09:19 AM
Top Avid Plug-ins Professor0086 macOS 1 02-21-2012 03:19 PM
