Region naming has changed
In a heavy edit session today, I noticed that the way names were assigned to edited regions was different than before today....
Before: Split whole file called "IVT_JohnDoe_01" results in regions "IVT_JohnDoe_01-01" and "IVT_JohnDoe_01-02" Split whole file called "IVT_BillSmith_01" results in regions "IVT_BillSmith_01-01" and "IVT_BillSmith_01-02" Split whole file called "IVT_PatBrown_01" results in regions "IVT_PatBrown_01-01" and "IVT_PatBrown_01-02" Split whole file called "IVT_SueJohnson_01" results in regions "IVT_SueJohnson_01-01" and "IVT_SueJohnson_01-02" etcetera.... Today: Split whole file called "IVT_JohnDoe_01" results in regions "IVT_JohnDoe_01-01" and "IVT_JohnDoe_01-02" Split whole file called "IVT_BillSmith_01" results in regions "IVT_BillSmith_01-03" and "IVT_BillSmith_01-04" Split whole file called "IVT_PatBrown_01" results in regions "IVT_PatBrown_01-05" and "IVT_PatBrown_01-06" Split whole file called "IVT_SueJohnson_01" results in regions "IVT_SueJohnson_01-07" and "IVT_SueJohnson_01-08" etcetera.... I've never seen this behavior before. It was keeping a running total of separated regions. Any idea what's up? MDD G4 dual 1GHz, 2GB RAM, OSX.4.8, PT7.3.1cs2, HD3
http://www.ripplefx.com Mac Pro 8 core 3.0GHz Harpertown Magma PE6R4I - HD 3 Accel +1 Process Control 24 - 96io - 1622 OSX 10.6.8 - PTHD 10.3.10 |
Naming region by default? | PPM6 | Pro Tools 9 | 1 | 01-25-2012 05:27 AM |
Separating/naming region issue | John calvert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-15-2010 06:04 AM |
Region Naming | mushoo | Tips & Tricks | 3 | 04-19-2008 05:57 PM |
Loop record and region naming | kalab | Pro Tools TDM Systems (Mac) | 0 | 09-20-2007 09:49 PM |
BUG: region-naming in 7.3.1cs1 | Frank Kruse | Post - Surround - Video | 1 | 02-20-2007 02:40 AM |
