How many watts?
I can't find anywhere this info. I need to know ho many watts does my 192 I/O, PRE, Control 24 conusme as well as a G5 Dual 2.0 GHz. Does anyone have this information? |
Re: How many watts?
V volts * A amps = W watts or VA Volt Amps
W and VA are not exactly the same thing but should be close enough for you to do what you need to do the difference is if you are measuring the voltage peek or RMS I believe
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Re: How many watts?
Thanks, I have a 650 watts No Break and need to know if it will be sufficient for protecting my system. Just to confirm: There's gotta be somewhere info. about how many volts and amps each unit has then I multiply them and the result is close enough to how many watts the unit conusmes right? Sorry to describe this with apple and oranges jeje but I need to be sure. |
Re: How many watts?
basically
volts is what is coming out of the wall say 120V so you need to find the Amp (A) listed on each unit (Digi you really should make this information easer to get to) so V*[A1+A2+A3...]
Re: How many watts?
Lee Blaske |
Re: How many watts?
OK, thanks. 192 I/O is 2A and we got 110 V so basically that is 220 watts or VA?, PRE is 0.5A so that's 55 watts or VA? I'm asking because the No Break is 1000 VA-650 watts so if we're talking VA's I'm OK but if that means watts I won't be able to protect everything. |
Re: How many watts?
The dual G5 is 7.5 amps or 825 watts. It's a tank. I don't remember the rating of the control 24, but it's not that extreme. Fortunately these things don't draw that kind of power. It's just a max rating. I have an APC 1000 which is 670 watts and runs a Control 24, 192 and one Dual 2.0 G5. Going on two years now and never an overload beep. Also have had several power failures and it held up fine. Of course the more the better. Another APC 1000 runs the second G5 and all my other toys. Hope that helps.
PT 7.4cs2 | OS 10.4.9 | Dual 2.0 G5 7g Ram | HD3 Accel | 4 FW800 Drives |
watts? | nerd513 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-25-2004 03:45 AM |
