region naming in loop record
Hi everyone,
I appear to be having a brain freeze and I can't remember if the following is possible. I want to be able to put ProTools into loop record and have it generate file names based on the region I have selected, not the name of the track it's on. Is this possible? I have made a lot of cues for Foley work and I would like to simply select each region and loop record with file names being generated as sequencial takes based on the region name. I don't want the track name used because I have multiple footsteps regions on a single footsteps track and I would like them all to be individually identifiable by which character they belong to. I know I could rename each region after I record it but that takes precious time on the Foley stage. Any thoughts or ideas on how to do this or imporve my workflow? Thanks |
Re: region naming in loop record
Double click the region, command c, double click the track name, command v. Track is named after the region. There is no other way that I am familiar with.
Eric Lalicata C.A.S. Supervising Sound Editor Re-Recording Mixer Anarchy Post 1811 Victory Blvd Glendale, CA 91201 818-334-3300 www.anarchypost.net |
Thanks Eric. That's what I ended up doing and it was pretty fast. This would be a nice addition for an update. Hint. Hint.
Region Naming | mushoo | Tips & Tricks | 3 | 04-19-2008 05:57 PM |
After Loop record-selecting different takes from Region list | Shanegrla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-10-2008 11:12 PM |
Loop record and region naming | kalab | Pro Tools TDM Systems (Mac) | 0 | 09-20-2007 09:49 PM |
Region naming has changed | ripple FX | Pro Tools TDM Systems (Mac) | 0 | 04-05-2007 04:36 PM |
BUG: region-naming in 7.3.1cs1 | Frank Kruse | Post - Surround - Video | 1 | 02-20-2007 02:40 AM |
