Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 09-29-2000, 03:31 AM
glava glava is offline
Default ATA disks with TDM
Is it possible to use the ATA disks(internal G4)
with TDM
Old 09-29-2000, 07:32 AM
Mount Royal Mount Royal is offline
Default Re: ATA disks with TDM
Search under heading "Troubleshooting with Mac OS" for ATA drives within the last 20 or so days. There are several posts from users making internal ATA/IDE drives work on G4 machines with 5.01 software. You may need to query those users concerning the track counts they achieved. Sorry to be unable to give specific references.
Pro Tools 2018.4
HDX, 192 and Lucid I/O
5,1 MacPro 12 Core; OSX 10.12.6
Old 09-29-2000, 08:43 AM
Eric.D Eric.D is offline
Yes, Mix plus running here with no
problems with track count or editing..
Eric
www.peaksound.com
Old 09-29-2000, 09:28 AM
davemc davemc is offline
Yes, Just migrated from NT TDM to Mac I use 2 internal ATA66 disks no problems apart from it takes about 5-10 seconds to start recording with 16 tracks. I am doing 64 track recording although they are not monster edits, 60% of the tracks go for the whole song. No Problems. These sessions came across from my NT scsi LVD drives to the IDE and are fine. I was told movies will be a problem although I do not do these.
Bye Dave
Bye Dave
www.indentmusic.com.au
Old 09-29-2000, 01:54 PM
editor editor is offline
No Problem ATA 66 or Firewire drives from APS-TECH.
Partial list of album credits/editor.
http://members.dslextreme.com/users/apple/
Old 10-01-2000, 01:03 PM
loopengine loopengine is offline
I only ran into problems when useing a full
frame full motion movie running on the
same drive (output with a miro card)
Solution was just to move the movie to
an old scsi drive I used for storage. Back to
a full session no problems with
an ata 66 7200!!
Old 10-04-2000, 02:16 AM
antonfrulio antonfrulio is offline
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by glava:
with TDM
<HR></BLOCKQUOTE>
On my PowerMac the new G4/400/ 20 Gb HD with Pro Tools 24 Mix / 888/24 i record and play 32 tracks on internal Disk without problem.
Old 10-04-2000, 07:33 AM
uno1234 uno1234 is offline
I'd suck it up and get a 10K RPM Cheetah-- you'll notice an enormous difference in performance and reliabilty. You've just spent 20K on a protools system-- why not spend another $800 on a 36 GB drive that makes your investment that much more valueable?
When you have big sessions, you need powerful drives. you don't want to deal with 5 seconds of a floating hand if you don't have to.
my 2 pennies.
[This message has been edited by uno1234 (edited October 04, 2000).]
Old 10-04-2000, 01:19 PM
mike connelly mike connelly is offline
"why not spend another $800 on a 36 GB drive that makes your investment that much more valueable?"
One reason is if you want to use the slot for something other than scsi. (plus for $800, you could have 100-150 gigs of IDE space) Have you A/B compared scsi with ide? What does the track count max out at with IDE? What reliability issues are there? I've heard of people getting 70-80+ tracks off of IDE drives, as long as you use at least 7200 rpm drives. From what I've seen, IDE isn't a step down in quality.
Mike
Old 10-04-2000, 02:16 PM
I cannot put up with slow computers and tapping hands. I've run my system off of IDE before, and found it to be slow and clunky. Sure, you can get plenty of tracks, with a medium edit density. But the user's ability to run the system quickly and efficiently is lost.
One example: your project has 30 tracks and a medium-heavy edit density. You hit play, and after 5 seconds of tapping, the song starts. Then, you realize you need to edit the beginning of the lead guitar solo. You hit stop, and zoom in 5+ levels to do the edit. Your system will slow to a crawl. It must access the hard drive during playback, and then again when you zoom in. An IDE drive cannot handle that expediently. And the client waits...
If you're a power user, it is a necessity to invest in powerful SCSI drives.
about to buy disks... Londoner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 09-29-2009 03:47 AM
OCW Disks - UK Matt Darcy General Discussion 2 02-02-2009 04:12 PM
New disks added, old disks audio files not loaded stevegalante Pro Tools TDM Systems (Mac) 3 05-14-2001 10:58 AM
will I get pt5 disks? rich morpurgo Pro Tools TDM Systems (Mac) 1 01-06-2000 02:58 PM
bad disks snoopy Digidesign Hardware & Software 0 10-22-1999 12:52 AM
