Eucon not working with 11.1.3
Anyone have Eucon working with 11.1.3? Can't get it to work anymore after updating.
Control and Mix are shown correctly in the EuCon app and Eucon is enabled in PT prefs but the devices don't do anything. Eucon v3.1.2 Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: Eucon not working with 11.1.3
after a bunch of restarts they are back.
gone again. after opening Spanner on my iPad the controllers are gone again. relaunch Eucon and they are back. hm...
it worked for me last night after the update...so far good...
Noticing the same thing - quit and relaunch Eucon brings them back.
Actually every time I initiate an ad-hoc network to my iPad for Spanner in the morning the moment the iPad connects my Mix and Control crash (displays freeze but EuCon still shows them as connected). Even power-cycling doesn't bing them back. Only thing that "fixes" it is re-launching EuCon which usually gives an "unexpectedly quit" message when you quit it.
Frank.
I had an issue last night now as well.
I started a new PT session and there was no response on the Artist Mix, even when I restarted the Eucon control and opened another session. I then rebooted and everything was working fine again...I have not had that problem before but at least I got it working again... very fragile system isn't it |
That's sad b/c I really want to like them....I think they are perfect for my setup and size....
But I can't risk Throwing away $2500 on some controllers that I won't get to use for their full potential. And i sure don't want something that i am fighting with from day one......I need to be more efficient not less. Cheers.
With Maverick, I had a lot of problem with Eucon 3.1.2 on PT 11.1.3
I returned on Eucon 3.1 and since then, my 3 surfaces run ok ! Did you try Eucon 3.1 ? Do you use Maverick ? see: http://duc.avid.com/showthread.php?t...ighlight=Brian
iMAC i5 with 32Gb of ram and Promise J4+SSD Sibelius Ultimate running PLAY using SO Plat+, SC_VOTA, HS Dia, RA, Silk, QLSV Pro Tools HD Ultimate & Prism Lyra2 |
+1 for trying 3.10 instead of 3.12. I found 3.12 completely unusable, incredibly strange crashes, behavior, the screen on the Artist locking to the wrong thing, like I'd be on EQ and it'd still be showing pan info, etc.
Went back to 3.10 and working fine with 11.1.3 |
Artist Control not working with Eucon 3 on OS X 10.8.4 | Jerry Woolsey | Artist Series | 1 | 06-24-2013 01:21 AM |
EUCON 2_6_1 eucon discovery cant find ip | klaukholm | System 5 | 2 | 10-22-2011 12:01 PM |
Alert - EuCon 2.5.6 is only for Pro Tools 9 and EuCon | DigiTechSupt | Artist Series | 11 | 02-24-2011 10:25 PM |
anyone have eucon working with artist series? | trock | Pro Tools 9 | 11 | 11-09-2010 07:28 AM |
Euphonix EuCon 2.5.2 - Pan Not Working | Carl Sealove | Pro Tools TDM Systems (Mac) | 3 | 01-20-2010 07:04 AM |
