is ANYBODY using FW800 out there?
I've posted four posts yet not one reply. Is anyone using FW800 with any success with PT or PT LE? Please, someone with a heart reply!!
By moving to FW800 would it possibly resolve all the conflicts I've been having with my 002rack and my external FW400 drive?
Pete Turok Powermac G5 dual 2.0 & Dell i8600 PTLE 6.2.2, 002r |
Re: is ANYBODY using FW800 out there?
i am hoping to pick up a 9 pin to 6 pin cable this weekend, or perhaps i'll hold off and order from granite digital
then i'll reply personally i have no conflicts and i have other fw400 devices, lacie d2 drive, lacie d2 burner, lino scanner, dv deck, ipod. delete the volume.ddb files everywhere (including the ones for removable media), and trash the reccommended prefs, as per suggested by digi. this once helped me out a bit. also try starting the mac, then restarting before doing any work, this has helped my scsi (sometimes fw) , drives properly register with the os. |
I have a firewire 800 port although I am not using it I believe . it is the the larger plug correct??
Yes - I'm using FW800 with a La Cie 500 GB "Big Disk". It just works. I did install the firmware update at the time i upgraded to 10.3.1 and haven't had a problem,
MacPro 8X 2.26 Ghz cores, 15 GB RAM, OS 10.6.8 PT9/Waves Platinum 8/Waves Restoration Bundle 8, W43/ Cedar DNS One/iZotope Rx2/Odds and ends |
Thanks JMP. I'm hoping I'll have the same success with the G5....so many unknowns it seems with the new G5's....
Fw800 | webstereo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-21-2009 04:13 PM |
FW800 port —> FW800 Drive —> Out FW400 port on Drive —> Pro Tools LE FireWire | maharzan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-03-2009 08:37 AM |
FW800 with OS9 | themaskedman | Pro Tools TDM Systems (Mac) | 3 | 01-22-2007 09:46 AM |
FW800 | jeremyroberts | Pro Tools TDM Systems (Mac) | 0 | 06-23-2005 03:27 PM |
FW800 | nbennett | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-12-2004 07:46 AM |
