Whats on your Master Buss
Tell us whats on your master buss, if anything?
Re: Whats on your Master Buss
Usually an EQ, then a compressor, and then a limiter followed by a dither if needed. Sometimes when the mix is sounding alright, I'll just put on that Izotope Ozone plug-in on the master fader followed by another limiter for a cherry on top (that Massey limiter I seem to like..amongst others).
Enjoy! Len |
many times, the Sony Oxford Inflator
last: PT11.3.1 |
UAD-1 Precision Eq and Limiter(maybe)
Waves SSL Bus Comp dither ... but make sure ur mix is good. Thats most important. |
While mixing I mostly use Inspector XL.
When it's all reasonably set up I'll swap in a URS compressor, 1970 or 1980 model, depening on the song/style. Then the Sony Inflator and Massey 2007. The latter to check what'll happen in mastering.
HDX-1 MacPro5,1 Raven MTi2, PT12.7 |
massey tape head (not always but more often than not)
Q-10 (hopefully a little or none at all A verb (Masterverb/Trueverb or Waves IR light) Just a little bit to glue things together L1 Ultramaximzer with dithering enabled Inspector (to make sure ther are no overs) Kind of pedestrian but works for me Brian
Pro Tools Studio 2023.12, RME UFX, Mac studio and a bunch of nice noise makers |
I always use either an unlinked Multimono AC1 w one of the Console presets tweaked to suit the material or unlinked multimono Antares Tube w blue tube and maybe 1.5db of drive. Followed by Inspector to make sure I'm not totally overdoing the bottom end.
I generally try to get the EQ and verb right in the mix rather than EQ or verb the whole mix. I prefer to leave this for mastering. On very rare occasions I will throw a URS compressor over the master buss, but again, I prefer to leave this for mastering. For cheap and nasty 16-bit bounces: If I want to see what limiting does I'll use one of the waves limiters - normally L3 but sometimes L2 depending how my CPU is going. Just started playing with the Massey L2007 - I think this is my favourite, but still getting used to it. Dither is normally POWr type 2 or 3. I tend to think less is more at the mix stage
gonzo HANSON'S RAZOR: Never attribute to evil that which can be adequately explained by stupidity. |
Just to throw in a different viewpoint(as I am sure all the previous posters get good results), I don't use a master fader at all. I mix for the best mix I can do and bounce at the same samplerate and bit depth as the session. If I am mastering, then I open my mastering session(same samplerate/bit depth) and import the bounced file. Here is where I will add any extras the track might need. First I trim the head and tail. This is also where I add a fadeout if needed. Then I insert Waves L2 in the last insert slot, set for no more than 2db of reduction and select dither for 16bit. L2 output is set to -.02 to avoid overloading. I might add a Pultec EQ to put a little sparkle on the high end. I might insert the PAZ frequency analyzer to look at spectral balance and I might add Waves Q3 if I really need some EQ, but honestly, if I need more than a little, I go back and remix. If it still isn't loud enough, I will add a second instance of L2 in the next-to-last slot and squash a little more(never going more than 2db of reduction). Of course, if I am sending the project to be mastered by someone else, I stop at the first step and give them the raw file so they don't have to try to undo something I did. This works well for me. As always, YMMV
When I am self mastering:-
SSL Master Bus Comp Massey 2007 Waves Dither Or SSL Master Bus Comp Waves L3 If it’s being mastered elsewhere, nothing… & they go out at 24 – 48 and I try and keep it all at -6 Cheers N |
SSL G Master Buss compressor /PT 8.0 | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-26-2009 10:28 AM |
how do you set or create a master buss | sbag | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-17-2009 02:31 PM |
Help Using RNC 1773 with octane and as master buss | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-30-2005 06:31 PM |
Master faders on buss pairs / BTD from buss pairs | tld | Pro Tools TDM Systems (Mac) | 5 | 11-19-2002 02:06 PM |
Outboard comp on the master buss | bassmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-12-2002 02:21 AM |
