If I ever needed help with a Digi 002...it\'s now!
Hey guys,
I've had my Digi 002 for 2+ years and never experienced the kind of problem I am right now. It's freaking me out a bit. Any session I open, the faders of the 002 will not respond by hand...they sit as if frozen by the motors. If you move them against their 'will', they have no effect on the session but quickly snap back to the set/original position. However, I can adjust the faders on the screen (with the mouse) as normal. ANY help that you guys can offer on this one is much appreciated. J.D P.S I replaced the power harness and supply about 1.5 years back. |
Re: If I ever needed help with a Digi 002...it\'s now!
It doesn't sound like the typical power harness problem BUT....I would still open the unit and reseat all the harness connections. I have to reseat mine every 6 months but 20 minutes and I am back in business. You never know, this might fix it or at least eliminate it from consideration.
Thanks for the post Albee.
Unfortunately, just tried that and no dice. Since I've come to depend upon the hands on 'control' aspect of the 002, this is killing me. |
J.D.
If it means anything, mine does this. I have deleted all instances of history, digi database bs, and pretty much rebuilt my machine. I noticed it started around the 6.9 era of Pro Tools. My faders work, however they do not keep their settings if I bank, etc. Automation works, but it sticks for a second. The fluid motion of the faders just is not what it was. Sad.... Thoughts DIGI SUPPORT? May have to start swearing on here to flag em? Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
Thanks Doc.
This definitely appears to be an electrical/mechanical problem with the 002 itself, which is particularly disturbing. I considered reinstalling Pro Tools until I realized I can move the faders on the screen and the corresponding ones on the 002 match perfectly...but try and do it the other way around....impossible. So it's not a program glitch. In fact, I tried different computers running PT and FW cables. The 002 faders not moving to the touch (or in weird, unuseable ways) is the one constant. Again, if anyone can point me in the right direction for a solution, it's much appreciated. J.D (Oh yeah, I've disabled groups and automation in multiple sessions to try and see if it was related to such things and it wasn't) |
i remember reading years ago people having problem with there faders on there 002's and it had to do with the eletrical outlet itself.
www.klarityrecordingstudios.com |
I don't know if someone already mentioned this but...
Did you try on the 002 itself - 1. restoring to defaults? and 2. Resetting the firmware? I can't remember the button combos off the top of my head, but a quick search would tell ya. Also, I heard that Digi developed their "final" power harness sometime early 2005. They had 3 revisions I believe. Depending on when you got yours, you might want to try getting the newest revision if you truelly think it could be power harness/power supply related. But from what I can tell, it seems like something else is wrong. The power harness would cause different problems like connectivity issues and stuck mute lights or no sample rate light...etc Good luck man! |
I had this problem about 2 years ago...after installing a new power harness...which apparently went bad too. A new harness from Digi solved the problem...
So now what, all we do is call DIGI and say "I need a power harness."
J.D.,
Just got off the line with Matt at DIGI and he is sending me a harness, etc today. I will swap it out and see what happens if it changes, etc. Thanks Matt for the help and I will let ya know. Doc
Advice Needed! Digi 001 and PC | jessmeaniesaid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-24-2006 11:30 PM |
DIGI - Help needed! | Imagine | Pro Tools TDM Systems (Mac) | 2 | 11-23-2004 02:14 PM |
Help Needed with my Digi 002 | digiman002 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-21-2004 08:00 AM |
Help needed with digi-001 | agent fu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-18-2003 08:47 AM |
Help needed from Digi please | mgbass68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-30-2000 06:40 PM |
