-9073 error
the recording keeps stopping and i get this message
dae cant get audio from drive fast enough,drive may be too slow or fragmented, or the firewire drive could be having trouble due to the extra fire wire bandwidth or cpu load -9073 |
Re: -9073 error
Same problem here.
Mbox2 - PTLE 7.1 cs6 - MacOS X 10.4.5. |
Re: -9073 error
I have received the same. I just did a search of the answerbase and will try this to see if it helps.
http://answerbase.digidesign.com/detail.cfm?DID=30183 Take Care, Gene
Unicycle Studios |
Re: -9073 error
How many tracks are you recording? What type of computer are you using? What drives are you recording to?
Have you tried all the steps in the OS X Setup and General Troubleshooting thread yet? Please provide as much information as possible about your system and how you're using it so that we can better diagnose where the problem is occurring. |
Re: -9073 error
6 tracks on a g4 power book to my hard drive....the other day we were doing 5 tracks and it did it and we turned down the buffer and it worked....then when we went to 6 tracks it was a no go
Re: -9073 error
I´m using my internal hard drive too. My session: 8 audio and 3 midi tracks (after reducing the number of tracks as much as possible).
No problem when recording audio or midi, but when trying to complete the "bounce to disk" it stops after a few seconds. Sometimes it seems to work, but suddenly the MIDI tracks play back out of tempo. Sometimes I get the -9132 error (bounce handler could not keep up). This session worked fine in PT LE 6.4 and is the bigger issue that I found after upgrading to PT LE 7.1. I tried the steps in the OS X Setup and General Troubleshooting, I repair disk permissions frecuently and even disconnected all my firewire and USB peripherals (iPod, external Lacie Firewire HD) but the problem persist. Should I try the "Spootlight index" option that Gene suggested? In any case, should I update to 10.4.6? MBox2 - PTLE 7.1 cs6 - MacOS X 10.4.5. Plug-ins: Pro Tools Ignition Pack, Native Instruments ACBox Combo. |
Error 9073 and Error Increase/Reduce H/W Size during playback Digi001 | Karma180 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-05-2011 07:46 PM |
Error 9073 | djobar | Storage Subsystems | 0 | 12-06-2007 08:06 AM |
-9073 error | darrylectomy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-28-2007 07:25 PM |
error -9073 | standish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-23-2007 05:33 PM |
adat loopback error#4 and error 9073 | uri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-22-2003 11:19 AM |
