Old 12-18-2005, 08:52 PM
yavuzj yavuzj is offline
Default Re: Power harness caught up, save my CD recording
It turned out OK.
Could have been a lot worse.
I still have lost 1/2 day that I had paid the musicians for.
No comment on should have been better prepared except, how can you prepare for a Tsunami question?
As I said, I could easily write 20 pages of why this should not have happened.
I choose not to.
Engineer had an 002 with a REPLACED harness.
So we used that.
I will check if it is not the harness.
One question...
Is 002 and 002R harness the same?
Yavuz AKYAZICI
Guitar Player, Composer
http://cdbaby.com/cd/volcano
http://volcanojazz.com
http://myspace.com/volcanojazz
Old 12-18-2005, 10:57 PM
scottedog scottedog is offline
Glad you managed. Not sure if they're the same or not.
Scott.
ScottedogStudios on ReverbNation
Old 12-19-2005, 07:27 AM
Gene Backlin Gene Backlin is offline
One question...
Yes.
Unicycle Studios
Old 12-19-2005, 07:47 AM
rocktron rocktron is offline
percussive maintainance will solve the problem in the short term.
(i.e. give it a whack!)
Old 12-19-2005, 08:12 AM
WitchdoctorD WitchdoctorD is offline
"clean the pins with a pencil eraser"- This can work remarkably well, but a better idea (and one that might prove a more permanent solution) is to get a can of Caig Pro-Gold contact cleaner and apply per the directions. This stuff is well known to work wonders on marginal contacts, not only cleaning them but also minimizing the formation of new gunk after the fact. If the contacts are really grungy, they have another product (the name escapes me at the moment) that is intended strictly for cleaning; no residual protective value. Hope this proves useful in fending off the power harness demon!
Old 12-19-2005, 10:22 AM
Mike Glenn Mike Glenn is offline
This reminds me of the pin connector problem on the first nintendo box.
002R Faults + power harness + no phantom power DaveSB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-26-2009 01:10 AM
002 power supply/bad power harness? please help :( djkiller 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 08:04 PM
New Power Harness tolovpeace 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-20-2005 10:26 PM
002 rack power harness power suplly issue rockstah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-06-2004 11:04 PM
BAD POWER HARNESS/POWER SUPPLY!!??HELP!! snuffacation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-11-2004 03:03 PM
