How do I find duplicate files and delete them?
I have three external firewire drives and I just bought a 500 GB drive. I would like to somehow delete all of the identical copies I have of my sessions and samples from the three drives and then back it up to one drive so I have free space again. I know I could use software like Retrospect or what not, but I am looking for a way to find files that are identical and delete one of the identical versions.
I could use the digi-browser and search for each folder on each volume and see what's identical... but isn't there a better way? |
Re: How do I find duplicate files and delete them?
For instance, Logic is capable of finding all identical files and lets you delete the duplicates while still leaving the orginals... Any ideas anyone?
Maybe I'm missing something here. Why do have "identical" copies of your Pro Tools Session file and samples on three drives ? The only way that this can happen is if you manually do a "save copy in" and copy your audio files to those other drives. You can do a search for the song title and just delete the associated PT Session and audio I believe.
This link explains how to do this with Terminal.
http://www.macosxhints.com/article.p...10828211333805
File management is really important in Pro Tools, and this sounds like a disaster waiting to happen! You need to have a system and stay backed up every day. Too many copys is almost as bad as too few, because it's hard to remember what's what, especially as time passes. Good luck. Steve
Steve Shepherd Extreme Mixing |
Here's what I would do...
Pull up the current session you are working on. Go to the audio bin and "select unused audio", then "Clear selected", then "Remove". Now do a "Save session copy as" and copy all audio files to your new drive. Open that session on the new drive to make sure it's all there, and then delete your original sessions. Of course the downside of this is that you will lose your unused takes, so don't proceed with this until you are further along in the mix or ready for archiving. If you just need to keep a working copy of the session in progress, then just drag a copy of the complete session to your new drive and then drag the entire contents of the audio files folder to the new audio files folder as you add more files. If you "don't replace" duplicate files during the copy process, then you will only be adding the new files in a session to the backup, and all file names and identifiers will remain the same. Copy the current session document as you go, and you will have an exact duplicate. Does that help, or were you just looking to get rid of multiple copies of files that may not be in a session? Not sure how you'd do that. Maybe some kind of utility? (EDIT: Just looked at the "Terminal" suggestion, and that may be the way to go. Thanks!) Sorry if I re-stated the obvious... Bob
Save early and often! (or once a day whether you need to or not...) |
Thanks Steve and Bob. You both make some very good points.
How to duplicate clips... that actually duplicate physical files? | mooquu | Pro Tools 10 | 4 | 06-04-2014 03:28 AM |
can automator find duplicate files for me on a hard drive | drguitar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-13-2008 09:31 PM |
how can i find files NOT in use by the session and delete them? | Miike Lee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-03-2003 08:58 AM |
