Loop Playback
Hi guys
I am having trouble with getting the loop playback to work in PTLE. When I check the Loop Playback in the Operations menu, I can see the loop playback icon around the play button in the transport window but there is no playback at the end of the song. Please help ! [img]images/icons/confused.gif[/img]
L.M.N. |
Re: Loop Playback
did you highlight a selection to playback. It will only loop whatever you highlight with your cursor tool. If you just hit play it will play forever and ever..
is that what you are trying to do?? |
Re: Loop Playback
Thanks for the reply. I tried highlighting as you suggested but still no cigar. Any other clues.
Regards
L.M.N. |
Re: Loop Playback
try selecting a region using the transport. you can type in the start time/measure, the end, or just put in the length. and by the way, if you hit no.4 on the numeric keypad, that will also put it in loop playback mode, you won't have to touch the mouse.
Jeremy Forbis |
Re: Loop Playback
Thanks J.FO, I am at work right now and will try your suggestion when I get home this evening.
Much appreciated. [img]images/icons/wink.gif[/img]
L.M.N. |
Re: Loop Playback
Also make sure you have the "link edit and timeline selections" button selected. It is located in the upper left hand corner of you edit screen just below your shuffle,spot,grid,and slip mode buttons
Re: Loop Playback
Hey J.FO
Thanks for the help. I inserted the start and end times as you suggested and it works great. What would I do without you great guys on the DUC. Peace [img]images/icons/wink.gif[/img]
L.M.N. |
Loop Playback in 10.3 - BUG | kronos66 | Pro Tools 10 | 1 | 09-19-2012 07:03 PM |
Loop Record and Loop Playback will not engage? | Angelo of Onello | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-28-2008 06:03 PM |
Loop Playback In 7.4 | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-09-2008 04:06 PM |
Loop playback in PT LE | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-04-2003 06:38 PM |
