Import Session Data: Automation does not merge?
Hi All,
I'm a bit puzzled at this and maybe you all can help me out. I have a master mix session where I'm importing session data from 6 different session (6 reels) with a bunch of automation (volume, pan, mute, plug-in). I am using the "Match Tracks" function in the Import Session Data dialogue too. So DX1 to DX1, DX2 to DX2, etc. I am noticing that as I am importing session data from each session, the previous import will be cleared of any automation as if the new session overwrites everything even though the reels are spread out over the timeline (Academy Leader style - 01:00:00:00 - 02:00:00:00 and so on). How does everyone work around this? Thanks. PT9 + CPTK2 |
Re: Import Session Data: Automation does not merge?
I think you have to use "Overlay New on Existing Playlists" or something like that, or it wipes everything before it
Yea. Even when I check that box off, it still wipes the preceeding import.
Becuase the "source" session is seen to contain "blank" automation data before the head of the reel - so it lays that blankness on top of prior material and wipes it.
Known issue AFAIK - you need to compile onto new tracks and copy up, hence track counts going up to 512 these days, to make this easier. I might be missing something but that's how I've most commonly seen it worked around. Boring. |
Thanks Brent! That's the answer I'm looking for!
After thinking about this for a quick second. It would be great to have a "Range" section in the Import Session Data dialogue indicating a start and end point (TC) to import..
Been begging for it too!!
I suggested that years ago as well. A product manager said "That's a great idea!"
import session data creating unwanted trim automation | zakco | Pro Tools 10 | 1 | 11-27-2013 02:51 PM |
Import session data from PT8 session / pan automation | bad jitter | Pro Tools 10 | 0 | 12-05-2011 06:17 AM |
import session data without audio data | rgalpin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-06-2010 01:49 PM |
Import track color in import session data | deardaddy | Pro Tools TDM Systems (Mac) | 5 | 06-11-2007 06:35 PM |
Import Session Data & Automation | trombino | Pro Tools TDM Systems (Mac) | 1 | 10-24-2006 09:21 AM |
